TST kit or not
Old Jul 29, 2009 | 11:02 AM
Trooper173rd's Avatar
TST kit or not
Good day everyone
I'm new here and I,m sure this has been bashed around but I could not find it. I have a 95 with an auto. I have straight pipes(3" split into a pair of 2 1/5) A BHAF and I have gages I also installed a valve into the waste gate line to increase the boost. I turned the star wheel and moved the plate forward.
My question is what more could I do(cheap) to her.
Thanks
Ken
Old Jul 29, 2009 | 11:57 AM
BigErksG2's Avatar
4k govenor spring kit.
Old Jul 29, 2009 | 12:06 PM
~Angry Tractor~'s Avatar
If you don't want to blow the cash on the kit just do a search for governor washer kit on here. It only costs as much as two washers and you get close to the same effect. Hope you have gauges too.
Old Jul 29, 2009 | 04:11 PM
patdaly's Avatar
Don't forget the fix the KDP..... No performance, but can save you a ton of cash.
Old Jul 29, 2009 | 04:18 PM
rootremblay's Avatar
I'd say the 4K kit as well, big gain for the money. Well, actually you might want to go with a 3K because you would need 60 LB valve springs with the 4k.
Old Jul 29, 2009 | 06:33 PM
recklesskelly's Avatar
do a search on "free gsk" and do that, also AFC mods are good. great write up on one of the other forums http://www.dieselram.com/showthread.php?t=184069 For cheap power adders thats about it as the stock trannys don't handle much more than stock HP. If real power is what you're after then you'll need a set of gauges and some transmission upgrades. Our 12 valve trucks can make a ridiculous amount of power just depends on how much you're willing to spend! good luck, welcome to the site.
Old Jul 30, 2009 | 07:05 PM
Question to Maxtorq or anyone else
Sir
I did the mods to the afc unit as suggested in Maxtorq's thread but when it comes to adjusting the star wheel I do not have access to a regulated air pressure. Is there a way I can do this manually and is there a starting point such as from all the why in three turns out for an example.
Thanks for the help
Ken
Old Jul 30, 2009 | 07:33 PM
infidel's Avatar
Adjusting the starwheel just depends on how much smoke you want on acceleration.
Start with it all the way forward and work from there.
Old Aug 1, 2009 | 10:16 AM
i was kinda hoping to make it to at least 35 before anybody called me SIR oh well. Infidel is right, everybody's tastes are different, just adjust it back till you get a good balance between smoke and acceleration. Regulated air just allows you to set it on the bench for the amount of boost that your particular setup allows you to produce.
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
