Transmission sensor
Transmission sensor
I bought a transmission temp gauge for my 96. I do not know what automatic tranny I have. On the passenger side I see there is four plugs that look like test ports can I put it in one of them and which one should I put it in. Pictures would help.
I'll go get a picture. Tell me if it's wrong!
Here we go. This picture was taken from under the passenger side.
You can see the pan, so hopefolly you can see where I plugged it in. Is this an acceptable location?
BTW, I haven't gotten mine much over 160 degrees. Normally, it will only come off of 140 (mininum on my Isspro guage) if I'm in stop and go traffic.
Using the test ports on an RE will give you readings but they won't be right.
Best place is the output line to the cooler. There are tee kits you can buy or you can buy the output line for a '94/''95 which has a port.
http://www.swagelok.com/search/produ...art=B-810-3TTF
The port for the sender is 3/8" npt (any other size you need 1/4" or 1/2" is also available).
Heres all you really need and its maybe $20:
So, cut my lline and splice this in? Looks like a ferrule compression type fitting. Is that correct? Or do I need to flare the ends?
Is there only one line on the driver's side? I can't remember. I was thinking there was two. Maybe one comes from the passenger side and crosses over?
Thanks!
I'm using this, it works well and it easy to install:
http://www.genosgarage.com/prodinfo....ber=VULCAN_VTA
You put it in the front hose under the radiator going to the tranny cooler. You want the hot line, just drive the truck for a bit and feel the lines.
tyssniffen
Feb 11, 2006 01:28 PM
Booost Almighty
Jan 1, 2006 01:41 PM
wildmann
Aug 14, 2005 07:15 PM
