transmission
Old Mar 26, 2005 | 10:43 AM
dunerr's Avatar
transmission
Ihave a 97 with a 5 speed. i recently lost 5th gear. I am going to do a quick fix until i can put away the money to change the shaft. my question is who makes the best replacement shaft>
everbody says theirs is best. some are full splined some are press fit. i was leading toward the standard but i read that because of the rings they use it doent hold the gear tight enough and the gear wares.
so what to do????
Old Mar 26, 2005 | 02:47 PM
bmoeller's Avatar
One place to try-
www.standardtransmission.com
Old Mar 27, 2005 | 05:15 AM
P.O.R.'s Avatar
have you checked out these guys,sounds like the answer..
http://www.quad4x4.com/index.html
Old Mar 27, 2005 | 08:44 AM
dunerr's Avatar
yes these are two of the options i have found. Piers also sells them. From the vendor theirs is always the best. What i am hoping for is to find out if antone has seen any problems with these fixes.
THanks
Dauntless
15
Aug 30, 2016 08:37 PM
dsl-nut
Mar 22, 2003 12:12 PM
quantrill88
Mar 19, 2003 05:04 PM
harleydog
Mar 13, 2003 07:34 PM
jonesr2
Oct 12, 2002 04:49 PM
