Transfer case vacumn line connectors
Old Nov 25, 2005 | 06:53 PM
Bobcat698's Avatar
My 4WD all of a sudden STOPPED working the other day. I didn't have time to check it out until today.
Turns out the big ICE BLCOK that had accumlated under my truck has ripped the lines free from the connectors by the transfer case skid plate.
Sure, you'd think I could just RECONNECT them, but NO, it took one of the connectors with it.
Does anyone know WHICH connector connects to which metal fitting?
Also, the red hose connector is still there, but the black line connector is MIA. Where do I get a connector or what could possibly work instead?
I tried tape and a ziptie to no avail
Old Nov 25, 2005 | 07:52 PM
TxDiesel007's Avatar
Garrett
meet me on messenger...
Tx
Old Nov 25, 2005 | 08:46 PM
Stamey's Avatar
When I encounter this situation I use a piece of rubber vacuum hose that fits over the plastic hose and metal line tightly.
Chris
Old Nov 25, 2005 | 08:48 PM
Bobcat698's Avatar
Chris
Ok, but do you know which line goes where?
Thanks!
Old Nov 25, 2005 | 08:49 PM
G1625S's Avatar
Chris
yup, that's how I'd do it, too. If all else fails, they have random vacuum collections in the ''help!'' section at the parts store. Could probably find something there for cheap.
Old Nov 25, 2005 | 08:58 PM
Stamey's Avatar
Thanks!
Not at this moment, but I can certainly check the 96 or the 99 in the morning. I was just looking at them on a 95 today, and darn if I can remember....
Send me a PM in the morning if you still need the info then. Someone may answer better tonight.
Chris
Old Nov 26, 2005 | 09:24 AM
infidel's Avatar
Thanks!
There are only two choices, just find which combination turns on the 4wd light when the transfer case is in 4wd.
Old Nov 26, 2005 | 12:08 PM
Stamey's Avatar
Looked under both my 96 and my 99. Red one is toward the front.
Chris
Old Nov 26, 2005 | 12:14 PM
Bobcat698's Avatar
My 4WD light doesn't work in the first place
Thanks Stamey
Old Nov 28, 2005 | 01:08 PM
justme-'s Avatar
You mean you are under the truck looking in the area and didn't think to follow the 2 steel lines from where they meet the rubber lines at the front by the axle back less than 3 feet along the frame remembering which tube is which and which is connected to the red hose???
Just went threw that myself last week.
Bobcat698
Nov 21, 2005 03:19 PM
Monty
Feb 24, 2005 08:14 PM
lenny
Jun 10, 2003 09:27 AM
