is the trans the same??
Old Feb 18, 2009 | 08:12 AM
saggonwaggon91's Avatar
Does anyone know if dodge used the same trans behide the v10 as they did the ctd?
Old Feb 18, 2009 | 09:00 AM
patdaly's Avatar
Yep, different Torque Converter though, more stall in the V10.
Old Feb 18, 2009 | 11:10 AM
gmctd's Avatar
Different bell-housing and bolt pattern, specific to the Cummins adaptor casting - VX starters mount below the block pan-rail - Cummins starters mount above the pan-rail - etc, etc...............
Old Feb 18, 2009 | 11:28 AM
Wicked500R's Avatar
Would'nt the internal gearing be different? The Cummins turns up to 2500 on most trucks... The V10 can prolly turn 4-5000... I don't see how the gearing can be the same... I can do 70 at 2000 rpm... How fast would the V10 be going if it was turning high rpm's in OD?? ... dangerously fast... Unless I am missing something... I think the internals have to be different
Old Feb 18, 2009 | 04:18 PM
patdaly's Avatar
Sure about that?
Every thing I have ever seen or heard has them the same transmission, just different TQ, including from people who have done the V10 to diesel swap.
Old Feb 18, 2009 | 06:34 PM
rattlerbob5.9's Avatar
Originally Posted by patdaly
Sure about that?
The governor is different also in the diesel tranny for example the weight has a brass color to it where the gasser one looks silver and is lighter in weight that is why it shifts at a higher RPM than the diesel.
Old Feb 18, 2009 | 06:35 PM
Valv's Avatar
They are the same transmission. I once bought one for a truck and then had it rebuild by Goerends, it is same except for converter
Old Feb 18, 2009 | 10:01 PM
gmctd's Avatar
The starter bulge in the 48RE bellhousing that fits the Cummins adaptor is just above the crank centerline on the driver's-side - the machined recess for the manual-cranking gear is on the passenger-side above the crank centerline, and which side has no starter bulge above or below the crank centerline for a V8 starter, which would attach to the block on the bottom surface of the belhousing flange, which starter would be mounted below the pan rail\crank centerline - this leads me to believe the transmissions are similar only internally, including the bolt-on overdrive section and the 13" torque convertor housing
Differential gearing, TCC stall speed, and PCM control are differences in operating ranges - the 48RE has an electronic governor
J Lent
60
Nov 3, 2009 09:14 PM
jmccart
Jan 18, 2007 03:26 PM
PeytonMaterne
Nov 29, 2006 09:14 AM
