Trans problem
Old Dec 1, 2007 | 11:48 PM
NorKal12valve's Avatar
im going to go ahead and change the trans fluid to atf+4 with a new filter. how do i get all that cheap atf out of there? out of the coverter that is? Thnaks Kodi
Old Dec 2, 2007 | 12:52 AM
wcbcruzer's Avatar
Originally Posted by NorKal12valve
i have some cheap autozone atf called costal??
Oh man... I think we found your problem. You NEED to have ATF+4 in there. Get it at Walmart. Supertech is fine, but it's gotta be ATF+4. Tranny fluid isn't like motor oil where you can use different brands and viscosities. If a tranny is made for a specific type of oil, you have to use that same oil. Our Honda Accord, for example, it's made for ATF-Z1 and you can only get it at the dealer. Change the oil and see if it improves. That's a start. Keep in mind that on a drain and refill you can only get about 8 quarts out. The whole capacity is something like 20 quarts (I think). So it might take a couple drain and refills till you get it filled with mostly ATF+4. Might even want to look at a shop to do a tranny flush. Usually those cost $150 or so but it gets out over 95% of the old fluid. Might be worth it if it's gonna cost the same as doing a few drain and refills yourself.
Old Dec 2, 2007 | 11:28 AM
im headed out right now to get the right atf and a new filter. Thank you.
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
