?trans over heating
Old Jan 8, 2006 | 11:58 AM
bad dodge's Avatar
?trans over heating
I have a 96 dodge with 206k at 120k I had the trans overhauled because it would not shift right. the shifting problem is gone but I have a new problem. If I run the truck hard for 1hr or so or pull a load the trans will not take off from a stop. the truck takes off verry slow with lots of smoke. when I am just running it easy and no load there is no problems. any ideas????
Old Jan 8, 2006 | 09:40 PM
RCW's Avatar
RCW
My first guess would be a bad torque converter, but it can also be that the bands are not properly adjusted or the clutches are slipping. Either problem will generate a great deal of excess heat in the transmission. But, if it is clutches or bands it generally will discolor the fluid and continue to get worse. In any case the transmission would require a pressure test to determine which it is for sure.
Old Jan 9, 2006 | 10:13 AM
TravisG's Avatar
Bad Dodge- it sounds to me like you put it in limp mode. If you shut the truck off at a stop light and then start it back up, does it take off fine?
There is a resistor that you can put in a line off the pcm. Or a valve body assistant.
Old Jan 9, 2006 | 09:58 PM
bad dodge's Avatar
I have not tried to turn off the truck when it happens. But it is going in to limp mode. Next time it happens I will try turning the truck off. Where can I find a resistor for the pmc.
This has been a problem for a long time and I just cant pull anything with this truck because of this problem so it is grate to hear something that makes senses to me and might I might not have to pay for a hole new trans.
Old Jan 9, 2006 | 10:32 PM
TravisG's Avatar
Bad Dodge- call Haisley Machine and tell Patty you want one of their Valve Body Assistant's. It comes w/ directions and everything. I think this will solve the problem.
Or you could call Dave at Goerend Brothers Transmissions and see if he thinks this is the problem.
bigthumper
Mar 14, 2007 08:07 PM
03sled
17
Feb 14, 2007 11:57 AM
aggiehorsepower
Sep 22, 2006 11:30 AM
boostjunkie1
Jul 28, 2006 12:54 PM
bigfoot
Aug 14, 2004 02:22 PM
