timing
Old 01-18-2008, 07:48 PM
Tennessee 12v's Avatar
timing
How do you and what is best way to advance the timing
Old 01-18-2008, 08:48 PM
Ru rammin 2?'s Avatar
You get all the proper tools then go to piers diesel for the timing chart. The setting depends on what setup you have. I just did mine today. The timing case has a plate on it with all of the numbers you need to get the proper reading. The tools are a dial indicator, socket to pull the delivery valve, dial indicator holder, barring tool, puller to pull the pump gear, and a good torque wrench that goes to atleast 150ftlbs. The directions are on www.dodgeram.org. That should get your rig timed.
Old 01-22-2008, 08:20 PM
Thanks for the info. But I dont know that much about the p7100 pump. Most of stuff I've done has been with 24v's. So what I'm looking for is step by step instructions. I looked on dodgeram.org but all I could find was the timing chart same with some other sites I looked on. So if anyone has this or can tell me where to find this please reply.
thanks in advance
Old 01-22-2008, 10:24 PM
bj-666's Avatar
http://dodgeram.info/tsb/1994/18-10-94a.htm
GR40RCapri
07-24-2006 11:47 PM
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
redhornet
05-28-2004 06:06 PM
Quick Reply: timing
