T/C lockup switch for the 12 valve
Since Iam in the process of upgrading my tranny Ive been thinking about adding a T/C lockup sw,even tho this tranny should hold the torque and power better with the upgrades,has anyone tryed to wire it to a floor mounted dimmer sw rather then a toggle sw on the dash....just seems ezer if its on the floor ??
Re:T/C lockup switch for the 12 valve
I think I've read some posts by guys that have used a dimmer switch on the floor...works OK..but you need to place it high enough or in a position where you wouldn't accidently actuate it. A better solution is a 3 position toggle on the left side of the steering column housing with a lock-up indicator LED light placed in a very visible location like the A pillar. 3 position toggle would be preferable because it would allow L/U like stock, or not allow L/U at all, or force L/U.
Just noticed you have a Transgo shift kit...how do you like it? Would you recommend it...don't have any issues with my stock auto yet...but it sure is a slush box! :'(
John havent tryed the Transgo out yet...my truck is still in the shop gettin the tranny replaced should be done on thursday.<br> Had trouble with gettin new cooler lines from the dealer Iam gettin rid of all the quick disconnect lines I will give a report on the whole tranny upgrade on this post...<br><br>http://www.dodge-diesel.org/yabbse/i...;threadid=6484
I think that the floor mount would be fine...just get a dimmer switch, and ground one side.<br>I used a dimmer switch for a Gear Vendors...worked great!<br>george
Hi guys, I would like to jump in here if I may---John, how would I go about wiring up a 3 way switch like you mentioned? I am always wishing I could control the L/U manually when pulling a trailer in the hilly terrain around here.
http://216.235.147.117/forums/showth...threadid=54464<br><br>See the above thread...BoldtsWagon explains how to install a "Goof Proof" 3 way mystery switch that incorporates a pressure switch to unlock the converter clutch if boost drops below the setpoint...eliminates the possibility of stopping with the TCC locked and killing the engine. Dennis Garret shows a pic of his installation of the switch on the left side of the steering shaft housing. Glad I could find this for you because I want to perform this BOMB too ;D
[quote author=John Fellman link=board=16;threadid=7197;start=0#70354 date=1037852730]<br>http://216.235.147.117/forums/showth...threadid=54464<br><br>See the above thread...BoldtsWagon explains how to install a "Goof Proof" 3 way mystery switch that incorporates a pressure switch to unlock the converter clutch if boost drops below the setpoint...eliminates the possibility of stopping with the TCC locked and killing the engine.[/quote]<br><br>I'm kind of lost as to why he has it set at 15psi. I usually only see 3 or 4psi on flat ground. Unless I'm not reading it correctly, his will unlock at 15psi (the vast majority of the time for me). I want my converter locked at freeway speeds.<br><br>What am I missing?<br><br>Tackett
Tackett, for normal road running you would use the lower position selection which allowed for normal lockup at lower boost. The pressure switch use during forced lockup is to prevent stalling the engine if forgetting to disengage lockup before coming to a stop. <br><br>Jerry
I'm interested in this "goof-proof" pressure switch, as I know somewhere, sometime, I'll forget. I'm like the earlier post though, going down hill, the throttle will be pretty light, disengaging the TC, so any hill holding will be lost. Anyone with experience on this setup going downhill?
[quote author=dalton4 link=board=16;threadid=7197;start=0#73613 date=1038554534]<br>Tackett, for normal road running you would use the lower position selection which allowed for normal lockup at lower boost. The pressure switch use during forced lockup is to prevent stalling the engine if forgetting to disengage lockup before coming to a stop. <br><br>Jerry <br>[/quote]<br><br>Thanks Jerry.<br>I have a three position switch on mine, and I really like it. I like it so much that I never use the lower "factory" position. It likes to lock up at 1,00 or 1,500 RPM - which is not so good for my power level.<br><br>I drive unlocked, and lock it as soon as I'm at 60. <br><br>I forgot to unlock a few times when I first installed the switch, but you learn to deal with it really fast. I just don't think it's that big of a deal.<br><br>The good part is that I can keep it locked when I need to lift off the throttle for a bit - I hate the stock "unlock for any reason" setting.<br><br>Tackett
Angry Johnny
Aug 23, 2016 05:01 PM
93dieselZak
Jun 16, 2011 06:10 PM
