Swap Vacuum to Hydraboost?
I've never done one but assuming the hydro unit with master bolts right up to the spot where the booster was about all you would need is a couple tees and some hose.
I've driven trucks with both systems and can't say one stops better than the other but one thing's for sure, if something goes wrong with the vacuum assist system it's a heck of a lot cheaper to fix than the hydro.
That sounds like a neat upgrade Balzac...
I take it the 3.54 is too steep to pull good in OD??? I think that 3.73 will be the ticket. When you have it done, I am sure it will be a good conversation piece at our next event...
As far as the Hydroboost, I don' t think its all that great.. I have to switch mine to a synthetic soon as if it gets hot, I can feel the brake booster in the steering wheel.
The vacuum assist should be more than enough to kick in those disks...
Will our rims fit over those calipers??
J-eh
The vacuum assist should be more than enough to kick in those disks...Will our rims fit over those calipers??
J-eh
dirtygoat
May 31, 2008 04:26 PM
