Stiff Accelerator
Old Mar 16, 2007 | 08:51 PM
Mslaughter's Avatar
Stiff Accelerator
My accelerator is really stiff on my '95, is there a how-to floating around somewhere on how to adjust it? Thanks
Old Mar 17, 2007 | 08:55 AM
TIMMY22's Avatar
you probably need a throttle cable and possibly the whole recall.
read this entire thread...
https://www.dieseltruckresource.com/...throttle+cable
Old Mar 17, 2007 | 10:09 AM
dieselfuelonly's Avatar
DTR question asker
LOL you should see mine on the 3500... the previous owner attached a random spring to the front of it where the cable connects and then to some place on the front of the truck... I'm a little afriad to remove it... could I be affected by this recall also? Where should I get a fix from?
Thanks!
Old Mar 17, 2007 | 12:12 PM
TIMMY22's Avatar
Thanks!
Read the thread i attached a link to above...
Old Mar 17, 2007 | 02:35 PM
Mslaughter's Avatar
It already has a new cable the dealer put on, the problem is it's adjusted way to tight. I just need to loosen it a bit.
Old Mar 17, 2007 | 08:24 PM
TIMMY22's Avatar
the extension spring may be to heavy or connected in the wrong place.
buffeagle
May 7, 2008 03:50 PM
fishermansteve
Feb 9, 2004 09:05 PM
Hoss
15
Oct 17, 2003 08:33 PM
tishmael
Aug 31, 2003 11:49 PM
Diesel fitter
Feb 17, 2003 09:39 AM
