someone replaced my turbo?
Old Dec 7, 2012 | 01:31 AM
DC199512V87's Avatar
Question someone replaced my turbo?
so i had my turbo off to finally get to drilling the divider and making the wastegate holes 15/16". when i had it off i noticed the tag on the turbo said wh1c. i was under the impression that a 95 has a hx35?? am i wrong or has this been replaced in the past? what are the specs on a wh1c then and is it pretty much like a hx35 as far as compressor map and safe continuous boost?
on a side note i cant believe i took so long to do this little mod! truck sounds better up top, runs way better up top, and egts are about 75-100 cooler! but boost also dropped by 4-5 psi under wot. is this normal due to less drive pressure now or is the wg spring getting overpowered and failing to stay closed now that there is more volume going thru??
Old Dec 7, 2012 | 10:07 AM
Tate's Avatar
Some '95's got the WH1C.
Your boost dropped because you drilled the divider and enlarged the wastegate, so it is evacuating more volume.
Old Dec 7, 2012 | 11:08 AM
Ic. guess u do learn something new everyday. so next question is it good for any upgrades like the 60mm compressor or am I better off saving my cash for a 63/68? Thing is cash is tight n I won't b able to afford the nice turbo til a couple more years. So would the upgrade b worth it? Just looking to cool things down a tad
Old Dec 7, 2012 | 01:11 PM
jstone44720's Avatar
The turbo upgrades are ok, but not really the best bang for the buck. They can make things cooler, and support a bit more power, but you have some untapped potential in free/cheap mods you can try if discretionary income is tight. I'm assuming your signature shows all your mods, so here goes:
Start with helping out your airflow into the turbo. http://www.cumminsforum.com/forum/ge...ck-airbox.html
That shows a cool and very cheap way to improve your truck and lowers EGT's.
Consider that approach before a bhaf or other CAI.
Look at opening up your exhaust system some. The stock muffler is not really a restriction, but who knows what else is under the truck clogging the works.
Old Dec 7, 2012 | 01:15 PM
All supporting mods r in place. bhaf, 4" turbo back exhaust. over torqued head bolts. let the chain reaction more fuel needs more air needs more fuel begin
Old Dec 7, 2012 | 01:48 PM
Tate's Avatar
You can buy a S475 for $600. Build a set of twins. You can build a set for less than what a S300 from a diesel shop will set you back. And it will drive much nicer.
Old Dec 7, 2012 | 02:03 PM
Ya I know n that's what I want but by the time I get a bottom turbo and piping...it will b over 1000 for sure. can't do that yet....n besides a modded top turbo would b better in the long run anyways no?
hey Tate u get ur parts outta Canada somewheres for a good price or order from the states ?
Old Dec 7, 2012 | 07:47 PM
Tate's Avatar
The upgrade that you'll get from a bigger wheel and bigger housing is going to be marginal. The twins would be the best bang for the buck if you can fabricate.
Depends what parts you are talking about. Driveline stuff I have been getting from Peak Diesel in BC, turbos I have bought from Turbo Resource in NM, Forced Inductions in Al, misc. turbo stuff online from ATP turbo.
Old Dec 7, 2012 | 08:07 PM
Of course twins are the way to go fabbing is not a problem but piping is expensive. Most of my stuff I get from peak diesel but was just wondering if there were other good shops in Canada so I could save some shipping on bigger items.
Old Dec 8, 2012 | 02:04 AM
Tate's Avatar
Piping will only cost a couple hundred bucks, depending what size and where you source it. I bought all mandrel bent 3 and 4" piping for mine from a muffler shop. You could probably buy it cheaper online if you search around.
Old Dec 8, 2012 | 09:39 AM
Noone in town can bend 4" here so that might hafta b outsourced. will look into it tho. gotta c what the tax return looks like
Old Dec 8, 2012 | 02:16 PM
Tate's Avatar
Buy the prebent pieces. For a typical piping setup, you'll only need four 90 degree bends of whatever size you're using. I used aluminized steel for all of it, and used some scrap steel and a spare oil drain for the primary turbo mount.
Old Dec 8, 2012 | 02:22 PM
Talking
Blast it Tate now u got me going out putting twins on my truck! just gotta explain to my wife exactly y my truck needs another turbo....
Old Dec 10, 2012 | 08:04 PM
9812vram's Avatar
"Old one's gettin' weak...."
"More air allows you to lean it out so it'll be better on fuel".... by the time she see's the next fuel bill you can beg for forgiveness... 'Course you could always say "Oh. Guess I was wrong..." Naaaahhh. Scratch that.
dd5087
Nov 29, 2009 11:53 AM
ethamblin
Nov 17, 2007 02:26 PM
DodgingTools
May 22, 2005 12:18 PM
