"Sewing Machine Oil" Manual Trans Fluid
Old Aug 7, 2007 | 08:55 AM
markm4's Avatar
Well, I checked my fluid last night by sticking my finger in the hole....
what I found was thin "watery" if you will oil (felt kind of like "sewing machine oil" or "3 in one"). Seems to me it is worn out, or someone put the wrong kind of oil in there. It had grey-black specks and powdery gook in it, but was otherwise clear.
So I'm thinking I will change it tonight with the closest match to factory original fluid I can find on my way home, probably Valvoline synthetic 70w90w. I was told the factory original was syntorq lt 75w85w gl-4.
Mark
Old Aug 7, 2007 | 09:46 AM
infidel's Avatar
I feel the wise thing to do is only use the factory recommend Castrol Syntorx even if it costs more.
Old Aug 7, 2007 | 10:47 AM
markm4's Avatar
doh, I guess I'm going to have to get some of the right stuff.
Old Aug 7, 2007 | 12:56 PM
markm4's Avatar
Cheap Bastard
Being the cheap fellow that I am, I ordered the AMSOIL MTG Product, after calling a Chevy dealer near me who quoted 22.89 per quart for the factory oil. AMSOIL MTG is 9.90 per quart.
A funny thing happened when I called though, that might explain the light oil in my transmission now. When I first asked for manual transmission oil, thet suggested their MTF product, which is a 5-30 weight product. I'm wondering now if that is what the previous owner put in there, and why the parts are "rattling around" in there so much.
Their MTG product is a 75-90w product.
AMSOIL claims the MTG product is a direct replacement for the factory oil.
Ideal for NV-4500 Transmissions
MTG is a thermally stable, extreme pressure formulation that resists heat, oxidation, acid build-up and varnish. It is the ideal gear lube for high temperature applications, including the New Venture NV-4500 transmission, which retains heat due to its cast iron housing and is often subjected to heavy loads and high torque from turbo-diesel engines.
AMSOIL MTG is the replacement fluid for GM part #12346190 and Chrysler part #4874459 (Chrysler specification #MS-9070).
......If my tranny falls apart...you can say "I told you so"
Old Aug 7, 2007 | 05:17 PM
Box5's Avatar
I think Amsoil is the only other ok choice for nv4500 oil. Gl-4
Syntorq
Mopar
Amsoil
Old Aug 8, 2007 | 10:59 AM
Hayseed's Avatar
Mine is all AMSoil and no problems!!
Old Aug 8, 2007 | 09:29 PM
300sd2500's Avatar
quad4x4 has the syntorq for $54 a gallon.
Old Aug 10, 2007 | 02:24 PM
markm4's Avatar
Put in my AMSOIL last night
I replaced the trans oil last night with the AMSoil, and it does sound a little quieter this morning with less transmission gear sound coming from it.
Thanks
Old Aug 10, 2007 | 02:26 PM
SPLnut's Avatar
How's she shifting?
Old Aug 10, 2007 | 02:33 PM
markm4's Avatar
shifing
she is shifting pretty smooth. It was decent before, but smoother now.
And there is less whirling, rattling etc.
The old stuff was pretty darn black looking.
Mark
mar67655
Mar 14, 2009 07:22 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
doomgaze
26
Sep 17, 2006 09:54 AM
CTDinMT
Sep 2, 2006 07:25 AM
mattn124
Oct 30, 2005 07:41 PM
