Manual trans fluid
Old Oct 28, 2005 | 04:50 AM
mattn124's Avatar
Manual trans fluid
This seems like a silly question to me,, but what kind of fluid should I put into my transmission? I have a 99 cummins 5sp manual. My manual and my chilton both just recommend a mopar part# type fluid. There isn't some particular grade I'm suppose to run am I?
ALso,, what about the transfer case? I was pretty sure that got dexron II or III ATF in the transfer case.
Deer season coming up, 4 hr drive, want to top everything off before I go.
Thanks!
Old Oct 28, 2005 | 07:20 AM
blackdiesel's Avatar
Registered
ya gotta go to the dealership for the trans and the transfer fluid. they want ya to use the mopar stuff. heck, theres even a different fluid for the 5 and 6 speed.
Old Oct 28, 2005 | 07:52 AM
Mopar1973man's Avatar
This is what your looking for... It ran me about 15 buck a quart but you only need a gallon to do you transmission. Dealer only item...
Old Oct 28, 2005 | 08:23 AM
crobtex's Avatar
The tag on my 5 spd says to use Castrol Synthetic Lt.
The manual also says it's not necessary to service it unless there is a loss of fluid.
Old Oct 28, 2005 | 10:10 AM
Ruralmedic's Avatar
The OEM Castrol Syntorq LT in the 5 speed is a 75W-85 GL4 synthetic gear lubricant. As stated, available from a dealer, or from standardtransmission.com for $54 a gallon.
Old Oct 28, 2005 | 02:50 PM
mattn124's Avatar
OK, thanks! I was hoping I could just pick something up for it at a regular parts store but I guess not.. oh well.. I hate to pay that much for fluids, but I guess it's worth it if it keeps everything working.
I havent even ever checked the fluid in my trans or transfer case, dont expect them to be low but you never know
So, was I right in guessing that the transfer case get atf?
Thanks for the replies!
Old Oct 28, 2005 | 08:43 PM
rich's Avatar
Having gone thru 4 5spds you need to change the fluid about every 60k if you tow and about 75k if you dont. The manual says 100k dont believe it. I run royal purple in mine and haven't had a problem called them first to make sure and they said it is ok
Old Oct 28, 2005 | 09:13 PM
crobtex's Avatar
I guess I need to change mine. I'm at about 170k with no problems. The clutch is getting a little puny though.
Old Oct 30, 2005 | 07:41 PM
Rattletrap1's Avatar
Redline MT90 in 5 speeds..MTL in 6 speeds wasn't it?
If just topping off...then the Mopar won't be too bad $. If changing...go Redline IMHO.
ATF+4 in a transfer case is not needed. Any Dexron is fine. I use Redline there too though (ATF+4 equivalent). $6.50 per quart for all of the above.
First diesel
Jul 19, 2014 11:42 PM
markm4
Aug 10, 2007 02:33 PM
icrider
Sep 27, 2006 03:10 PM
doomgaze
26
Sep 17, 2006 09:54 AM
CTDinMT
Sep 2, 2006 07:25 AM
