Pump Problems?
Old Jun 27, 2008 | 11:17 AM
Bram's Avatar
Question Pump Problems?
I had a shop install a rebuilt P7100 215Hp pump for me. The problem is the truck is now missing at idle. The tech believes there is a stuck plunger on #2, because there is barely any fuel coming out at the pump.
The pump timing was set at 13*, the tech bumped the timing up seven clicks to a total of 20* timing. There is absolutely no bottom end power at all now! I told him I wanted it at 15.5* because I tow a lot.
Truck has #10 and 3GSK installed, any recommendations on the pump?
Old Jun 27, 2008 | 11:47 AM
aksparkey01's Avatar
20* is way too much without studs and o-rings. put it at 15.5 and make sure that he is using the correct lift for the 215cpl pump i bileve you want about 5.7mm of lift. thats a good start. mabie a bad injector also letting compressoin back in to the fuel line also. any white smoke to speak of when its idleing?
Old Jun 27, 2008 | 11:53 AM
Bram's Avatar
Originally Posted by aksparkey01
20* is way too much without studs and o-rings. put it at 15.5 and make sure that he is using the correct lift for the 215cpl pump i believe you want about 5.7mm of lift. that's a good start. maybe a bad injector also letting compression back in to the fuel line also. any white smoke to speak of when its idling?
Thanks, I haven't seen, or driven the truck yet this was all from a phone call from the tech, so I don't know about the white smoke.
He did say he tried a different injector and it still did the same thing. Tech said there is no fuel coming from the IP side.
Old Jun 27, 2008 | 02:30 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
No fuel coming from the IP side???Is that the main line your talking about...Place a fuel pressure guage on the pump and check if pressure is ok...
Old Jun 27, 2008 | 10:42 PM
Tate's Avatar
Why not just pull out the #2 DV and holder and verify if its stuck or not?
Old Jun 28, 2008 | 08:17 AM
Bram's Avatar
That's exactly what I asked him. He's waiting for the Boss to get back in on Monday, I guess I'll see what happens then?
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
k9judge188
Feb 9, 2006 07:42 PM
TPilaske
16
Nov 22, 2002 08:15 PM
