Proper procedure to adjust valves
Old Nov 3, 2005 | 10:28 PM
leadfootdodge's Avatar
What is the proper procedure to adjust valves on a 94' D3500 with automatic?..Has a 131,000 miles on it and never done so its time I guess..
Old Nov 3, 2005 | 11:52 PM
Dr. Evil's Avatar
Look here:
http://www.dodgeram.org/tech/dsl/val.../12_valve.html
Old Nov 4, 2005 | 07:05 AM
Great!!! Now I gotta gitter done!!! lol..
Old Nov 4, 2005 | 07:19 AM
robert chilton's Avatar
The valve adjustment is a cake walk. Get yourself a straight set of feeler gauges as they are easier to work with on the rear cylanders. Also roll the #6 valve cover towards the passenger side to remove. If you do it right it will come right off of the truck. Otherwise you will scratch your head for 15 minutes going what the heck. I think the first time took about half an hour. You might want to go ahead and replace the valve cover gaskets while you are in there. I think it was easier to do the valves on the cummins than an old small block chevy. Take your time and have fun.
Old Nov 4, 2005 | 04:53 PM
GearHd6's Avatar
Does anyone use the reverse rotation procedure to adjust the valves? It seems much easier to do to me. Its also easier to rotate the engine by the alternator nut too.
Old Nov 4, 2005 | 11:52 PM
fschiola's Avatar
It's the easiest way to turn the engine over without a barring tool.
Old Nov 5, 2005 | 01:19 PM
Rockyhud's Avatar
I got an email from Piers Diesel a while back, giving the steps to adjusting valves using the reverse rotation process (using the alternator nut to turn the engine). If anyone needs this you can PM me.
Steve
Old Nov 5, 2005 | 01:42 PM
jrs_dodge_diesel's Avatar
Check out my gallery. I realize its a 24V but it might be good for some visuals. I took those pics when I did my valves.
Old Nov 5, 2005 | 02:07 PM
GearHd6's Avatar
Yeah I found the reverse procedure in an old Trailer Life magazine and i've kept the magazine ever since. Thats a VERY easy method in my opinion.
Old Jan 2, 2010 | 01:30 PM
97_Dually's Avatar
Thank you Evil, for that link,
and to the top.
XCLR8N
Feb 20, 2009 01:49 PM
marv h.
Jan 5, 2009 11:19 AM
KRB
Apr 29, 2007 08:41 PM
APD
Mar 21, 2006 07:51 AM
greenwing
Dec 20, 2005 09:42 PM
