Problem Hookin up gauges
Old Feb 27, 2008 | 01:25 PM
dodgedually96's Avatar
I got my gauges in finally, and when i went to install the boost gauge, i ran into a problem i dont have a T connector thingy, if i unhook the line from the AFC it dont run right (with boost gauge hooked up) but when put in the AFC runs fine (no boost gauge). do i need to buy a T thing or what ?
Old Feb 27, 2008 | 03:28 PM
BBWD's Avatar
The boost gauge usually connects into the air intake manifold. On the stock manifold there are 2 plugs - one to the front near the fuel pump that you remove and install the fitting for the boost gauge. You have the Banks system and I do not know where you hook into that for the boost gauge.
John (DH)
Old Feb 27, 2008 | 03:41 PM
dodge_kid9712's Avatar
http://www.cumminsdatabase.com/read.php?id=83
go here..the t fitting thing didnt really work for me.. you will see the other end of the line that runs to the afc is connected to the intake man.....it is used so there will be another one just like it more toward the front of the truck that is not used just plugged...go to napa and get the fitting to go in there 1/8........that waht i did i just took the line to make sure the ferrule and line fit right..
Old Feb 27, 2008 | 04:43 PM
smokeum99ta's Avatar
Heres where I hooked mine up
another pic
Hope this helps
Old Feb 27, 2008 | 05:47 PM
Dartmouth 12V's Avatar
You can either do something like the picture just above or buy a boost bolt from any vendor. You just remove one of the bolts in your intake manifold and put it in there.
06dodgedrw
Competition / Pulls / OffRoad
13
Mar 20, 2007 07:45 PM
StrokeThisCTD
14
Sep 5, 2005 09:50 PM
Kman9090
Aug 30, 2005 07:57 PM
FrdRdnk
Aug 28, 2005 12:09 PM
MasseyMan1089
Dec 7, 2004 09:49 PM
