Power steering pump tank leaking
Old Mar 21, 2005 | 08:06 AM
niekrewb's Avatar
The tank on my power steering pump is leaking.
The bottom of the tank looks a little rusty but is solid.
Although it seems as if the fluid is weeping right through it.
It dosent seem like the hoses are leaking.
Does anyone have any experience with swapping out the pump?
Thanks in advance.
Old Mar 21, 2005 | 09:19 AM
John Faughn's Avatar
I'm just going by bad memory here , once you have the pump on the bench there are some bolts and or nuts on the back side that you remove then the sheet metal can will side off sometimes with a little help, once off there will be a O'ring around the pump body that should be replaced, if your lucky this may be were the leak is , if not then with some cleaning and insection you should be able to see where else it could be leaking, all the parts should be avalible one at a time from a napa.
92smokin blacky
Mar 30, 2010 06:09 PM
One Way
Mar 26, 2005 02:15 PM
Twalker
Feb 3, 2005 11:31 AM
BLK_RAM
Dec 31, 2002 12:10 PM
USMC64-70
Nov 25, 2002 11:13 AM
