Changed Power Steering pump now leaking oil badly
Old Jan 25, 2005 | 01:06 PM
Twalker's Avatar
Just changed my PS pump , the shaft on the old one was a little beaten up on the end, but the new one went into place ok. Now however the pump is working but it is leaking oil around the shaft when the engine is on . I took the pump back off and tried to take the bracket off that holds the pump on but no luck. Has anyone had this off if so how do you do it. Or is there another way to fix the leak.
Old Feb 1, 2005 | 05:32 PM
DRESSER DAVE's Avatar
Is the leak,engine oil? Vacuum pump seal may be bad,What was your reason for replaceing p/s pump?
Old Feb 3, 2005 | 11:31 AM
Twalker's Avatar
The ps pump was bad, no steering or brakes. It was leaking oil because of a bad seal on the vacuum pump, got that fixed and now everything is working fine.
Tie Dyed
Aug 11, 2008 06:15 AM
ptgarcia
Jun 19, 2008 11:15 AM
OTR PU
Aug 28, 2005 06:51 PM
piperca
Jan 25, 2005 05:11 PM
wrk24wheel
Oct 18, 2004 12:26 PM
