P7100 Leaking Oil
Old Jul 2, 2007 | 09:14 AM
Txwelder's Avatar
P7100 Leaking Oil
Is there a common leak on the P7100? It is not leaking from the AFC housing but under and behind the fuel shutoff solenoid. Any ideas?
Old Jul 2, 2007 | 12:34 PM
clutch1's Avatar
shaft for the shut off solenoid, plug to gain access to gov. springs, timing pin cover
Old Jul 2, 2007 | 12:37 PM
mr T's Avatar
there is an access cover there...probably loose....its the access cover when you adjust the lever for the plate...
do you mean behind the pump as in closer to the back of the truck?...
Old Jul 2, 2007 | 12:44 PM
Txwelder's Avatar
I mean behind as in up underneath and behind it looking from the drivers side fender. Maybe I need to find a picture to identify what may be the culprit. Leaking oil all the way down my track bar and leaking onto the ground. I would say that is alot.
Old Jul 2, 2007 | 12:48 PM
mr T's Avatar
yeah there is an access cover there that probably came loose
Old Jul 2, 2007 | 12:51 PM
mr T's Avatar
http://cumminsdatabase.com/read.php?id=2
the 2nd pic is a pic from behind the pump with the access plate removed...check to see if the leak is from there
Old Jul 3, 2007 | 09:42 AM
Txwelder's Avatar
No picture there. Maybe wrong link? Thanks anyhow.
lilsuzuki4x4
Sep 1, 2011 01:50 AM
Hercules
Nov 26, 2009 01:15 AM
Txwelder
Apr 6, 2007 11:21 PM
Bobcat698
Oct 30, 2006 08:37 AM
