P7100 oil line fitting size?
Old Nov 25, 2009 | 05:00 PM
Hercules's Avatar
I found a couple more parts missing on my brother-in-law's truck when installing the pump today. First, is the fitting the oil line connects to located on the side of the pump between the block and the pump. It's within a few inches from the overflow valve. Does anyone know what size fitting it is? I'm wondering if it's an ansi #, but, I'm not sure. Also, is there a part # for the 3-way vacuum fitting off the afc housing...it's missing too? Hopefully this finishes all the missing stuff off his truck. Thanks for the info!!!
Old Nov 26, 2009 | 12:30 AM
Tate's Avatar
IIRC, the oil fitting is a M14x1.5mm male to a -4 JIC/AN male. AFC is 1/8" NPT male into the AFC, 1/8 NPT female for the other two connections. Should be able the first at Cummins or a hydraulic shop. The second you should be able to find at a Napa or similar.
Old Nov 26, 2009 | 01:15 AM
Hercules's Avatar
Thank you very much!!! The oil fitting was the one I really wasn't sure about. That info will make things much easier. I'll have to figure something out for a 3-way connection at the afc. He doesn't seem to be receptive to eliminating the line going from the 3-way to the wastegate and use a boost control elbow tapped into the turbo like I did on mine. I just hope if I overlooked anything else that was missing it's easily replaced. This truch has been passed around between at least 3 owners before he got it. The rub is, it's pretty much in pieces. I hope to have the pump timed and the front end back together on Friday. If all goes well, it should be running early next week. Thanks for the info!!!
sdseva
Jul 27, 2010 05:50 PM
RollsCoal
May 20, 2010 01:14 PM
maineram94
Oct 5, 2009 05:25 AM
johnls
Apr 1, 2009 01:51 PM
wheelin66
Aug 30, 2006 02:30 PM
