p7100 wrench size?
Old Oct 4, 2009 | 10:02 PM
maineram94's Avatar
Question p7100 wrench size?
Does anyone happen to know what size socket is needed for removing the big nut holding the timing gear to the pump? Also are the four bolts holding the pump on require any special tools?
After I removed my high pressure lines from my injectors I noticed some fine particles had fallen into the top of the injectors, So I took a can of p. b blaster and sprayed it in there to flush it out. Any thoughts?
Thanks, Blain
Old Oct 5, 2009 | 02:38 AM
Tate's Avatar
Big nut is 30mm. Four nuts that hold the pump to the case are 15mm, universal and extension will be your friend.
I prefer to wipe the crap out of the injector inlets, but as long as it gets out is the main thing.
Old Oct 5, 2009 | 05:25 AM
maineram94's Avatar
Thank you Tate, I was just concerned if any particles might have made their way deep inside the injector.
CZSteve
Jan 6, 2018 02:38 AM
bobva
Nov 26, 2006 11:16 AM
trik396
May 31, 2005 05:09 PM
1tuffdiesel
Jun 27, 2004 06:29 PM
turbov6joe
Oct 28, 2003 06:10 AM
