Excessive oil on side of p7100
There is alot of oil on the drivers side of the pump and it has leaked all over the drivers side motor mount. After driving almost 2000 miles in five days there was oil dripping off the fuel pre heater. What could cause all this oil to be coming from the pump? It is below the AFC only and doesnt seem to be coming from the AFC. Thanks.
EDIT: Run some dye in it...
Valve cover gaskets have been changed recently and inspected quite a bit with all the valve noise I think I have. They arent leaking. Again, this is only under the AFC, not above. I thought there was some kind of plug on the pump that was prone to leaking?
It's amazing how reading many posts we can relate with SAME EXACT PROBLEM happening.
My son in law '98 12v has same problem, but it feels more like fuel than oil.
There is the return line to pump that has a fitting and it was a little loose, I tightened it and we'll see what's happening.
Took me a month to find that leak
I had a problem similar to this when I bumped my afc housing foward, oil leaked from between the afc housing and pump. Cleaned it up and ran a small coat of RTV sealant between the afc and pump and the leak stopped.
If the valves leak too often you might try and grind out a little of the inside of the valve cover maybe with a dremel, did that to my #6 valve and haven't had any leaks since.
muddobber40
13
Oct 10, 2006 04:02 PM
CumminAtYa
Oct 8, 2003 03:11 PM
