overheating towing w/ new radiator
Old Jul 16, 2011 | 02:02 PM
mrcbmlasvegas's Avatar
thank you wccruzer, went with am cobalt. to save money im going to mount them in that opeaning were the drink holder is .allways forget not to use it. drinks fall out- big mess
Old Jul 16, 2011 | 02:30 PM
Originally Posted by cj360trider
id stick a temp gun or aftermarket temp gauge on it to compare it w factory gauge. your fan clutch will always slip jus a lil bit. even when "locked" it will technically slip a few rpms. is your temp light coming on as well. if i recall correctly the pcm has a different sensor than the gauge and if you can find some one who can connect a scan tool to the truck and see what the PCM is seeing that wud be another thing to try
got a temp gun . factory guage acurate .temp light hasnt come on i allways back off peddle to keep temp below the red line overdrive button off . im thinking how much heat is the trans adding to my eng.cooling system w/the heat exchanger.? still no scan tool . maybe change timing ?
Old Jul 17, 2011 | 05:51 PM
cj360trider's Avatar
if the trans is a question you may try a temp gauge for it and a nice size aftermarket cooler possibly w an electric fan mounted on it. also you said you replaced the water pump a year ago...are you assuming its still good or have you physically checked the coolant flow? i know a guy that went thru 3 water pumps inside of 10 months....i think he ran into a bad batch or somethin like that. also wanting to verify that your fan shroud is present and in tact.
Old Jul 17, 2011 | 08:10 PM
the trans is only a question becouse , location of heat exchanger.lots of compounded heat. eng block, 1200 deg turbo exhaust &manifold.when pullin a hill everything is building heat add desert 100+ temps doesnt every thing work against it self w/ exchanger?.coolant flow is turbulant,hav a shroud and that fan moves more air than anything ive seen.trans cooler is a great idea . ill check how much $.i need coolant in temp & coolant out temp on a truck that is not having cooling problems to eliminate nu radiator .thank you for your reply.
Old Jul 17, 2011 | 09:38 PM
you shud have a good 40* drop in temp between ur upper and lower hose and it shudnt be over 210* realistically
Old Jul 17, 2011 | 11:17 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Run it and feel the trans lines. If they are red hot, then investigate it
Tell me more about this Rad you installed.
How about some pictures of the front of the truck.
Thrashingcows is back from vacation.
Old Jul 17, 2011 | 11:42 PM
man i hope i do . ill put in nu stat tommaro ( didnt like the napa)& make a test run & check w t- gun should be about 105 out tomaro 10 deg more with ac on & im packen.
Old Jul 18, 2011 | 12:23 AM
hey steve sorry i havent checked out your tip. been busy . you know ive wasted a week on e bay ,won bid on egt $91+10 to ship only to hav seller charge another 101 seller charges?? no guages yet.test run tommaro il l get trans temps rad is 2wide cores 2-3/8in made in china plenty of fins nu mounting hardware grt fit $136 shipped genisis auto.you wana see my costom front bumper mounted tire /20 gal deisel &tool box holder ..just send me instructions on how to do that .gotta go now aintbees turn to use the apple2 thanks yall
Old Jul 18, 2011 | 12:39 PM
Polaraco's Avatar
eGay You need to be real careful over there. There's allot of car dealer tactics
Old Jul 20, 2011 | 01:17 AM
e bay is a waste of time. i saved a few bucksbut since i didnt talk w/sumone im sure i dont hav 100 percent of install hardware. my water service broke under my driveway havent looked at the dodge . have a nice day
Old Jul 24, 2011 | 05:52 PM
got my guages in ,30 on the boost wot,280-380 at idle cant remember ,1200deg in about 1/4 mi. temp gun comfirmes temp. after test rad had foam bad head gasget i supose . any shops here in vegas to serface ,o-ring check for cracks? any tips thankn have anice day carl
8liter
Sep 22, 2012 10:19 AM
jdcone
Apr 17, 2006 02:11 PM
jb42942
Sep 10, 2005 07:26 PM
Ram2001
Jul 21, 2005 07:03 AM
belfert
25
Sep 14, 2004 05:50 PM
