Our Stock Auto Trannies!
Old Nov 1, 2004 | 12:40 PM
  #31
Mcmopar's Avatar
SMR is a company out of canada, cost depends on the year 94-98 is about 149 USD, the 1998.5-2002 is about 163 USD. I like it better because you use valving to aviod the trouble/check engine light instead of a .20 resistor, which will burn out over time. The shift points seem to be much better. The 1-2 shift is about 10-12MPH instead of 2-3. The 2-3 is also higher. Parts are very nice quality. I have done a few SMR units now and they just work really well. Ask mike-D I did his this weekend.
But this is America and that is just my opinion!! To each his own, and I am not trying to "bash" anybodies product, I like SMR.
Old Nov 1, 2004 | 01:08 PM
  #32
cumminsdriver635's Avatar
No feeling hurt here . I was just curious, as ive never heard of SMR before. Also, my transgo doesent use a resistor since i have the 47rh tranny, so i dont have to wory about that happening. Thanks.
eric
Old Nov 1, 2004 | 01:31 PM
  #33
Mcmopar's Avatar
I just try to clarify when I have an opinion that it is just my opinion, not fact!!!
Old Nov 1, 2004 | 06:09 PM
  #34
kd460's Avatar
Mcmopar, any difference in install on the smr? Easier or tougher than the transgo? Seems to me there was alot of discussion about smr about 8 to 12 months ago. Seems it was all positive regarding the smr. I'll see if I can dig up the info. Kevin
Old Nov 2, 2004 | 10:34 AM
  #35
Mcmopar's Avatar
Both are about the same "difficulty" level, there is no soldering with the SMR kit. Depending on the year of the truck using the Trans-Go kit you need to install the resistor
Old Nov 2, 2004 | 02:12 PM
  #36
FANZDSLPWR's Avatar
i called transgo today and they told me there really isn't a diff between tfod-hd2 and tfod-diesel. he said the hd2 is for the gas motors and the diesel rigs. he said when i am done with the shift kit the only thing that will be left over is the parts for the gas jobs. whew i thought i bought the wrong shift kit. he did recomend a synthetic fluid along with the shift kit.
Old Nov 15, 2004 | 06:50 PM
  #37
MasseyMan1089's Avatar
So if I install a Transgo, I can choose to keep it in od/lockup all the time? Im looking for someway to get some smoke from the auto. I know you can get stuff for smoke, ive read about all of it, but I just turned the star wheel, so it smokes before the turbo spools. So with the Transgo, can I keep it locked and lug the engine for some smoke? Or do I not have the right understanding?
Old Nov 15, 2004 | 07:54 PM
  #38
No. You cant do it with the transgo itself, but if you install a TC lockup switch, it will, and youll have all the smoke you can make when you lug it in overdrive, and its rolling it out . All you need is a 3 dollar toggle switch and some wire.I love mine. You can find instructions on TST.
Eric
Ex03AK
Nov 1, 2010 10:46 PM
Ole JIM
Nov 8, 2006 07:52 PM
MiniC
Sep 23, 2006 11:39 AM
NC_Mog
Jun 20, 2003 05:37 PM
