Clutch ??
Old Nov 12, 2004 | 03:55 PM
kandgo's Avatar
Clutch ??
To whoever has a Mu-13-1.25 con ofe, does it work well when backing up a loaded trailer well?? Any problems with it chattering when backing up slow with heavy load?? Any other dislikes or put my mind at ease with some positive comments. I am in need and have talked with both Luk pro gold and the south bend owners. Thanks Rick
Old Nov 12, 2004 | 04:52 PM
Oakman's Avatar
Sorry this is kindof off-topic of your question, but what did the LuK owner have to say about his clutch? Ive got one also (Pro-Gold) that I put in for a stock replacement before major BOMBing on the mind, but its holding ok with the added hp. Any insight would be great. Thanks.
Old Nov 12, 2004 | 09:07 PM
kandgo's Avatar
I have only talked with the owners of the company's, not the owner's of any of the clutches themselves. I do hope to hear from some of them. How much hp are you making with your progold in and is it really holding? Do you tow any heavy loads? Thanks Rick
Old Nov 13, 2004 | 12:48 PM
Larry R's Avatar
SB MU13.125 con ofe
I have this same clutch, have had it in for about a month now and would recommed it, I also pull a toyhouse 5th wheel and have had excellant results. The clutch was a little pricey but well worth it in my opinion.
Old Nov 13, 2004 | 05:37 PM
kandgo's Avatar
Thanks Larry, I was hoping to hear some more positive results about it than I have gotten. Especially in the area of backing up a heavy load when needing to go slow as in heavy bucking and such. Thanks again.... Rick
Old Nov 16, 2004 | 12:14 AM
Oakman's Avatar
My pro-gold is holding fine, but I'm worried about adding power. I don't tow heavy loads regularly, maybe 6-7k every now and then. I haven't put the truck on the dyno so I don't know how much its actually holding, but Ive got an advertised 100+ hp plate on my 215 pump with 38"s and 4.10s and haven't slipped it yet and Im not easy on it. However, I wouldnt recommend getting this clutch if youve got big power in mind, it's smooth as hell and been great with maybe 30k on it, but like I said...Im worried about whether it will hold with a set of 370s since I havent heard of many people with this clutch. I guess I'll find out though.
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
