Ok. How bad is it
Old Nov 10, 2010 | 06:23 PM
jtandgwen's Avatar
Ok. How bad is it
Just purchased this truck a couple of months ago;
It's a plain truck, no upgrades that i can tell.
2000, 3/4 5.9, auto.
It has several things that need to be corrected and will work them as fast as i can.
First problem is the exhaust.
It starts out as a 3", goes into a "free flow type" muffler (that is what i was told). It comes out as (2) 2 1/2 (dual's) and goes out to the rear bumper.
I was told that would be ok because it "should not back up" pressure.
I am unsure about this system. This should be like a cake walk for you expert's.
Is it ok OR should i replace it. I plan on pulling a 31" 5er with it.
Thanks in advance for your inputs. It is very important to me bacause i am as green as they come.
Thanks
Attached Thumbnails Ok. How bad is it-000_0049.jpg   Ok. How bad is it-000_0050.jpg   Ok. How bad is it-000_0051.jpg   Ok. How bad is it-000_0052.jpg   Ok. How bad is it-000_0053.jpg
Old Nov 10, 2010 | 07:35 PM
rebal's Avatar
GET rid of it And put a good 4" on it because it will breath better a 4" will flow more then 4 2"ers looks like a home made job
Old Nov 10, 2010 | 08:05 PM
GAmes's Avatar
I just changed over to a 4 inch system because my 3 inch finally rotted out. No difference in mileage, performance, exhaust temps or anything else. A very good source, who made 800hp with a 12 valve on #2 diesel alone determined after dozens of dyno runs that a 4 inch isn't needed until you exceed 400HP. Do the basic pi R squared math and determine if your two 2 1/2 inch pipes have the same or more space than the stock 3 inch. BTW, looks like a pretty good job to me.
Old Nov 11, 2010 | 07:34 AM
patdaly's Avatar
Change that pig out, you may not need huge diameter pipes, but those bends are not doing you any favors.
Looks like a typical Muffler shop glom job.
Old Nov 11, 2010 | 10:52 AM
blackimpala's Avatar
I agree with GAmes You don't need bigger pipes untill up start upping the H.P. If you want to spend the money put it somewhere else in the truck, gauges maybe torque converter or valve body kit. I think its a clean looking professional installation.
Floyd
Old Nov 11, 2010 | 12:18 PM
macattack_ga's Avatar
Drive the truck! There will be something that NEEDS to be fixed soon enough.
Old Nov 11, 2010 | 04:29 PM
rebal's Avatar
If your going to haul a 5er get rid of them they will turn your 5er black and all the exhaust will be blown through the trailer + you get HOT gases blowing strait on the 5er you need to loose it or at least get them turned to the sides!
Old Nov 11, 2010 | 04:43 PM
gorms's Avatar
I agree with what rebal says. At the very least turn them out. I wouldn't be overly concerned with backpressure, with no cat (I'm assuming) it should flow pretty good.
Old Nov 11, 2010 | 05:48 PM
infidel's Avatar
Use your money on a pyrometer first before wasting it on exhaust replacement.
It could very well be you don't need a bigger system but you should have a pyro anyway.
Old Nov 11, 2010 | 07:13 PM
jtandgwen's Avatar
Thanks for the information. I was concerned about the system function, everything else looked good to me.
My next priority is gages.
THANKS.
Old Nov 19, 2010 | 10:19 PM
turfguy's Avatar
Talking
I have 3" duals on mine; def get them out towards the sides. Get a pyro & it will tell you if you're overheating the turbo; you may not need to remove the duals anyways.
You may want to remove the muffler; I'm thinking once you start pulling it may overheat it & turn it colors-keep an eye on it.
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
design
Mar 3, 2003 07:07 PM
doomgaze
Feb 6, 2003 06:51 PM
