NV5600 questions, buddy has trashed two
Old Mar 25, 2008 | 11:29 AM
DRKelly's Avatar
A friend of mine has been having a real hard time with transmissions in his 98 model. The input shaft on the original NV4500 broke. He had that transmission rebuilt. About 3-4 months later something else inside broke. He then replaced it with an NV5600. The first one the company shipped him had the incorrect input shaft size. The second one they shipped him started making noise after about 100 miles so it was pulled and replaced with another unit. That one made it maybe 10,000 miles, started making horrendous noise and then got stuck in sixth gear. Bottom line, who sells a bullet proof NV5600? Or is there a better transmission to swap in? Yes, the truck has some power mods, but nothing really ridiculous.
Thanks,
Danny
Old Mar 25, 2008 | 01:33 PM
HOHN's Avatar
It sounds to me that the rebuilds were flawed. A properly rebuilt NV5600 will last a long time.
A company should know better than to ship an NV5600 with the smaller input shaft.
The NV5600 is a great trans-- but it needs proper care and maintenance.
FYI-- I use Redline MTL lube with great results, changing every 30K.
jh
Old Mar 25, 2008 | 05:13 PM
Homestead's Avatar
145,000 miles on mine and only ever had oil changes.
I won't say I beat on mine but it gets worked good most of the time either towing or more spirited driving.
It sounds to me like something was wrong with the rebuilds.
Jeff
Old Mar 25, 2008 | 05:20 PM
Troutstrannysvc's Avatar
The NV5600 w/ the 1 1/4" Input which I presume is in your buddys truck as you stated "The first one they sent had the wrong size input" Which would've probably been the 1 3/8".
Anyways, the 1 1/4" where known for syncro problems, so they redesigned some things and came out w/ the 1 3/8" in 01.
I'll look into it, or you can I'm sure you'll dig up something!
Old Mar 25, 2008 | 05:47 PM
Copenhagenjunkie's Avatar
I would call blumenthals in oklahoma city, ok. They did the 5 to 6 speed conversion for me and I have had no problems.
outside304
Jun 12, 2010 06:14 PM
jmccart
Jun 6, 2008 06:55 PM
CCOUGHRAN1
Mar 26, 2008 11:20 AM
samgovol
Sep 25, 2007 10:07 PM
CTD2001
Mar 14, 2007 10:59 PM
