Idle Bounce and lights too???
Old Mar 25, 2008 | 07:23 PM
rollerink's Avatar
I have started to notice that at idle my truck (1996 2500 with 220k) bounces between 700 and 500 RPM. Same things happen at night when the lights are on, as the RPM bounces the lights either get brighter or dimmer. Anyone else experience this problem or am I just imagining it????
Old Mar 25, 2008 | 07:32 PM
rollerink's Avatar
Just updated my sig
Old Mar 25, 2008 | 07:52 PM
aksparkey01's Avatar
probally your grid heaters coming on. if thats it it should quit when its warmed up.
Old Mar 25, 2008 | 09:49 PM
Dartmouth 12V's Avatar
It sounds like your idle is too low. It should be about 850 in drive with the AC on and the engine warm. The alternator cannot put out much current at really low rpm which could explain the dimming lights. I would start by adjusting the idle up and seeing if the problem goes away. Once that is out of the way, if it is still bouncing, you can look for other problems.
Old Mar 25, 2008 | 09:59 PM
Common's Avatar
Check the 90* plugs that go into your grid heater relays - I'll guarantee one is loose.
This same thing happened to me and drove me crazy for at least a year.
Search through my old posts...
quicksilvr
Jun 21, 2010 01:33 PM
walexa
Feb 26, 2007 02:40 PM
tomgreentwin
May 21, 2006 09:51 PM
bauer500
Nov 15, 2004 04:24 PM
routerguy99
Nov 18, 2003 10:29 AM
