nv4500 leaking on trips
Old Jul 12, 2010 | 11:17 AM
Intercool's Avatar
Im having an issue with my nv4500. Whenever i take it on trips or at sustained speeds of 65 or over it sprays tranny fluid up on the exhaust pipe and leaks from somewhere. If im just driving it around home etc it never leaks. What gives???
Old Jul 12, 2010 | 01:55 PM
Midnite's Avatar
Sounds like you need to figure out where it's leaking from. Maybe a seal needs replaced?
Old Jul 12, 2010 | 03:07 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Clean if off to find the leak...Could be automatic transmission fluid out of the t-case or expensive oil coming out of your 5-speed...I had a similair problem...It was the t-case seal..
Old Jul 12, 2010 | 09:38 PM
Intercool's Avatar
it is expensive tranny fluid. i know this already. it is coming from what appears to be the top of the tranny???
Old Jul 12, 2010 | 09:53 PM
roughstock's Avatar
Might be the thick rubber gasket between top plate and plastic shifter housing. Ive had them go bad.
Old Jul 13, 2010 | 12:50 AM
Lil Dog's Avatar
Or the shift boot may be torn under the interior boot. I would check the vent to make sure it isn't plugged.
Old Jul 13, 2010 | 08:09 AM
roughstock's Avatar
Shift boot doesnt keep oil in trans. at least not on his 02.
Old Jul 13, 2010 | 11:11 AM
Intercool's Avatar
i forgot to mention this is on my 1997. thanks for the info guys!
Old Jul 13, 2010 | 01:40 PM
There are two versions of the NV4500 shift covers..Thats a good idea....Check your vent tube...That sure sounds like your problem....I hope..
Old Nov 30, 2010 | 09:50 AM
Intercool's Avatar
where is the vent tube located?
Old Nov 30, 2010 | 10:19 AM
I am thinking the vent tube is plugged or missing .
Hopefully..
It is at the top of the case behind the shifter on the passengerside if I remember right.
It is pretty short.
I have seen this happen from overfilling them as well, did you recently add/change fluid?
Old Dec 1, 2010 | 10:23 AM
infidel's Avatar
Me too.
They get overfilled when people mistakenly think more is better and add the fluid by removing the shifter and pouring the oil in from inside the cab rather than using the fill plug which is engineered to make it hard to overfill.
Using more than the designed fluid level makes the tranny run much hotter and expands the fluid till it pukes out.
Old Dec 1, 2010 | 03:19 PM
Intercool's Avatar
if it was overfilled wouldnt it leak all the time? this seems to leak only when running above 60-65mph and on sustained speeds. i dont know if the guy who worked on it messed with the tranny fluid. i know he added some t-case fluid.
Old Dec 1, 2010 | 03:35 PM
No, it could only leak when it got hot enough and expanded, and then puked out the beather tube, just like you are describing.
I sold a guy a NV-4500 a few months ago.
He over-filled the tranny before re-installing.
He emailed me as to why it was puking fluid when on long trips at high speed after he installed it...
It was do to over-filling the NV-4500 before being installed.
Could be your problem.
LanceK
Apr 16, 2006 07:52 PM
herb
20
May 1, 2005 12:33 AM
TexasBlake
Dec 1, 2004 10:00 AM
alltork
22
Jan 26, 2004 11:58 AM
Sohio
Apr 23, 2003 11:48 PM
