Noise under load
Noise under load
I just got my first diesel. It's a '94 w/ a 5 spd and 192K miles. I recently towed with it (1200 miles round trip, ATV in bed, towing car trailer with a 4k lb. truck on it), and noticed a noise after about 350 or 400 miles. I had it in 5th with the cruise set at 70. The noise is hard to describe - more solid sounding than an exhaust leak but not too metallic. Kinda like a valve clearance issue or a dead lifter and it only occured under higher boost levels. It wasn't too bad but bad enough for me to shut the cruise off and try to make it "work" less.
Any ideas on where to start looking/listening? I searched earlier but didn't come up with much. Sorry if I missed something.
Thanks,
Ryan
Thanks,
Ryan
Maybe you just noticed it after 400 miles because you werent paying attention, then you heard it and it was all you could concentrate on.
These motors make all kinds of noises.
It won't be long before you know when and where each sound will come from/happen.
Nah, it was a new noise. My wife even asked "what's that?" as it got louder. I was able to keep it from happening by getting a run on a hill and then easing up at light throttle. It seems to be boost related or at least load related.
Can you get it to do it at idle?
Maybe a U-Joint on its deathbed?
Could be a boost leak.. Hard to say. You might just want to check all the hose clamps to/from the turbo, intercooler and intake to be sure. Also the intake manifold bolts have a tendency to come loose over time and can make funny noises under boost.
Gauges?
Gauges?
No gauges yet. I'll have em soon though. I also need to do a bunch of maintenance - oil change, fuel filter, valve adjustment/check, etc....
SeanB23
Apr 16, 2010 06:20 AM
PsychoRallye
Feb 11, 2008 09:15 PM
Dodgezilla
Feb 13, 2004 03:40 PM
