No Throttle response
Old Aug 29, 2015 | 10:11 PM
jeremy01995's Avatar
hi, i have a Ram Cummins 1994 with a motor from A 1998 12v. i have 24-25psi fuel pressure idle, and 30-31psi 2500rpm no load. i run with my truck. and 10-15 min later, suddently,i have no throttle response, and the rpm is stable( example 80km/h at 1700rpm, the rpm stay at 1700), 10 sec later the throttle response come back...
Fuel Filter is new!
tanks for helping me!
Old Aug 30, 2015 | 08:06 PM
no one have idea?
Old Aug 31, 2015 | 07:59 AM
patdaly's Avatar
Sorry, I can't think of anything right now............. That's a new one on me for a P7100..
Old Sep 1, 2015 | 08:50 AM
Throttle cable is frayed and getting stuck….Maybe?
Old Sep 1, 2015 | 08:51 AM
yeah.. maybe... but it dont explain why the motor stall when i press the clutch,. :/
Old Sep 1, 2015 | 09:30 AM
First I heard of the clutch problem, or even that you have a manual in your truck.
If you would like help with a problem, it is best if you list what the problem is, completely.
Old Sep 1, 2015 | 09:39 AM
looks like the governor not working proprely
Old Sep 1, 2015 | 07:22 PM
gorms's Avatar
Kind of sounds like pump issue.... Make sure the shutoff solenoid is working properly, and the little arm that connects to the shaft on the pump for it is tight, and the itty bitty woodruff key isn't lost.
Does pump have GSK in it? Maybe pull governor plug and check both spring retainers/springs to make sure they are set properly and springs aren't broken or missing!
Old Sep 14, 2015 | 06:21 PM
when i run, between 1500-2000rpm the fuel pressure goes up and down...( between 5-40psi) non stop... lol
NO LEAKS, NO AIR LEAKS. it do it with a hose direclty from a jug of fresh fuel to the lift pump.
Old Sep 18, 2015 | 12:07 AM
pind's Avatar
Air leaking in at the o ring on the primer pump
uncleroty
May 19, 2006 01:37 PM
Camp
May 10, 2005 03:20 PM
getblown5.9
Apr 22, 2005 10:02 AM
BillH
Feb 19, 2005 01:16 PM
Twodiesels
19
Feb 12, 2005 06:38 PM
