New Noise
Old Oct 7, 2006 | 02:11 AM
Brendan's Avatar
Smile New Noise
Hey guys, I'm getting this noise in the cab when the drivetrain is under load. it sounds like a ticking coming from the transfer case. There is no noise when slowing down or cruising, just when you lean into the throttle. Any help would be great!
Old Oct 7, 2006 | 11:31 AM
arroyojim's Avatar
i have the same noise and it drove me crazy until bigger things started braking. now that i have those fixed i guess i can worry about the ticking again...anyway, i have looked for something loose on top of my t-case and can't find anything so i guess it's internal, but don't really feel like tearing it down right now. maybe this spring...
Old Oct 7, 2006 | 05:32 PM
mr T's Avatar
check ur rear driveshaft u-joint and rear drive shaft carrier bearing if u have an extended cab...
Old Oct 7, 2006 | 07:10 PM
Brendan's Avatar
Thanks mr T, on another note, do you have a sputter around 1100 rpm?
Old Oct 7, 2006 | 09:27 PM
kelownadiesel's Avatar
yep check the steady bearing ,mine have gone on both my trucks and it makes the same noise you are talking about
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
crashinaz
Mar 30, 2004 02:23 PM
ronw
Jul 29, 2003 11:16 AM
swank
May 28, 2003 08:52 AM
