Need help Guys
Old Jul 18, 2007 | 09:08 PM
NCLandscaper's Avatar
Need help Guys
Got a 94 3500 with a fuel problem. Line from IP to injector is leaking at the pump. The line is for #6 and I have loosen and retighten and it is leaking again. This fix lasted about week and half. Please I need help as I aam taken a trip Friday and would love not to leak fuel all the way there. Thanks in advance.
Old Jul 18, 2007 | 10:27 PM
Box5's Avatar
so it's leaking at the dv (delivery valve) right? There was a recent thread about fixing a leaking DV, i'll try to find it... I think u'll just need a new washer and o-ring for that number 6 Delivery valve.
Thanks to txdiesel007 i think this will fix ur problem
https://www.dieseltruckresource.com/...d.php?t=159242
Old Jul 18, 2007 | 10:30 PM
Captain's Avatar
get a new O ring. You may or may not have a washer in there too. Lube it up and tourq it as it says. Its in 2 steps like tourq to 45pounds and then in one motion to 90. dont quote me on the numbers, just the process. I had a leaky #1, the O ring was all torn to peices in there.
Old Jul 18, 2007 | 10:33 PM
Cummins Freak's Avatar
hey if you NEED/ Cant find an o-ring i have one and could over night it to you for the cost of the ring and the shipping
Old Jul 19, 2007 | 04:24 PM
the leak is come from the top where the line exits the IP. When I took it out prevously there wasnt a washer there. I wish I could take pic for you guys. I appreciate the help. Going to take it apart again and retighten.
Old Jul 19, 2007 | 04:40 PM
rough drawing to help. The leak is right where the line enter the top of nut.
Old Jul 19, 2007 | 06:53 PM
clutch1's Avatar
its a flared end on the injector line most of the time when the start to leak you can tighted them just to stop the leak until you drive to pick up your new line, the only fix. once you tighten them thats all you get you need a new line.
Old Jul 19, 2007 | 06:56 PM
clutch1's Avatar
if your really in a bind you can try smoothing out the flared end of the line with some emery cloth but thats just a bandaid, it will start to leak again.
Old Jul 19, 2007 | 10:31 PM
thanks clutch1. That is what I was afraid of! Where can I get new line? Can you make them like brake line? Thanks again guys.
Old Jul 19, 2007 | 10:36 PM
clutch1's Avatar
there is no making these lines very high psi and they're a certain length so you'll need to go to a cummins shop, big rig shop, or a tractor dealer for the new line.
Old Jul 20, 2007 | 11:49 AM
Found a place online that has them just waiting to see how much. Thanks again guys.
Old Jul 20, 2007 | 04:04 PM
halerazor's Avatar
call haisley or one of the other performance shops i'm sure they have some laying around
RyanF
Dec 21, 2008 03:07 AM
04ctd
Sep 10, 2006 02:58 AM
bentwings
Jul 9, 2004 02:23 PM
cumminsdriver635
Jan 9, 2004 10:04 AM
