Mystery horsepower
Old Nov 9, 2007 | 01:29 PM
Lurch's Avatar
Mystery horsepower
I bought this truck a few months ago. Been busy remodeling/moving so haven't really had time for anything beyond maintenance type stuff. Put it on a dyno about a month ago and put down 350hp. Felt pretty good about that.
Today I finally had some quality time with the truck. Opened up the pump to find a stock plate set in the middle. So my question is what injectors could put down 350 with a stock pump?
Lurch
Old Nov 9, 2007 | 06:50 PM
heykw's Avatar
please post picks of the fuel plate
Old Nov 9, 2007 | 06:57 PM
Box5's Avatar
Are u sure u have the stock hx35 turbo? But then again, u have a 215 pump, so those things do put down alot bigger numbers with less mods.
Old Nov 9, 2007 | 07:32 PM
Lurch's Avatar
No pics but I do have the shot showing all the various profiles and it matches the stock plate.
Checked the turbo early on. It is the hx35. Makes 36lbs if I drive it like it's stolen. No EGT issues even towing 10k.
350 was on John's(floor It) dyno. (Somebody's gonna ask)
Old Nov 9, 2007 | 09:25 PM
JKM's Avatar
JKM
Could have injectors and/or DV's.
Old Nov 9, 2007 | 09:31 PM
smkn97s's Avatar
How much black smoke do you have?
Old Nov 9, 2007 | 09:51 PM
displacedtexan's Avatar
That was gonna be my guess. The HX35 will support that much fuel.
Old Nov 9, 2007 | 10:44 PM
Lurch's Avatar
Just a good puff at low boost. Clears up quick. Will maintain a haze at full throttle in hot weather. What I'm looking for here is what size injectors might they be? Seems from looking at sigs 370's alone wouldn't put out quite that much and probably be smokier. Frame of reference, these would have been from 4+ years ago. Last owner had no clue about any of this. All work done by original owner. So that rules out the latest/greatest stuff.
Old Nov 10, 2007 | 08:00 PM
Ramdriver15's Avatar
dyno may be off a little. and also 370 sticks can put down up to an extra 90hp.... and if they had Dvs too it would put u up there. If the plate is in stock location then i bet the starwheel is too, which will account for the less smoke. Im guessing that the starwheel has to be in stock or tighter position to produce the lack of smoke! this is a nice running truck though from the sounds of it...
Old Nov 10, 2007 | 08:17 PM
Lurch's Avatar
Actually the star wheel was full forward. Housing was all the way back though. Of course I couldn't leave well enough alone and slid the plate up. Only had a short drive in traffic so I couldn't play much but definitely smokier and hits harder. Can't afford to be down with a clutch till I'm done moving and get a house sold so can't get too carried away.
370's and DV's might get there but wouldn't they be smokier/hotter? 4+ years ago I was immersed in the overvalved/electronic world so I'm not even sure what the hot setup was for the 12v's.
Old Nov 10, 2007 | 08:40 PM
I would think that much power with 370s and DVs would be pretty smoky.
Maybe bench work on the pump?
Old Nov 12, 2007 | 06:52 PM
Lurch's Avatar
Even with bench work it seems a reach. Maybe I'm just underestimating the 12v. Can't wait till I can start really playing.
Old Nov 12, 2007 | 07:13 PM
cumminsdriver635's Avatar
Hmm, thats pretty confusing. At 350hp it should be getting warm no matter what the setup is(plate, dv's, injectors). Is the pyrometer post turbo? I made a few less HP than that, and even though my truck is great towing, she will peg the 1500* gauge on a hard run from 0-60 or so. I would also think your truck would be smoking a decent bit too. Does it feel stouter than a newer dodge(3rd gen)?
Eric
Old Nov 12, 2007 | 08:41 PM
Lurch's Avatar
Pyro is pre-turbo. As stated above, if I slide the plate up it gets real smoky. Turned the star wheel back but haven't had time to really ring it out though, been busy. Haven't been in a 3rd gen but have seat time in faster trucks than mine. Pulls strong.
Old Nov 14, 2007 | 12:23 PM
Lurch's Avatar
Had a little time to tinker yesterday. Stock plate full forward. AFC housing forward, starwheel about 1/3 back gives me reasonable smoke and EGT's are good 1st-4th. Hold it in 5th and I can make 1500 but not till about 80mph. Don't know what that will do to my towing temps yet. Now I need more air so I can start grinding.
BEHRMAN
Apr 3, 2003 05:02 PM
DieselDaze
Jan 2, 2003 09:04 AM
Hummin Cummins
Dec 2, 2002 09:51 AM
gitchesum
Oct 28, 2002 01:15 PM
