Tanny ID Help?
Old Nov 12, 2007 | 12:44 PM
HelenaTDI's Avatar
Tanny ID Help?
Recently purchased 12v w/auto. I am trying to identify which type of tranny manufacturer this maybe. I was told it had a shift kit, different valve body, torque converter, etc.. The drivers side of the tranny is shaved and stamped with the following:
#5 PK52119519AA 3233 2069
Any help would be appreciated.
Also Dr Performance did the injectors and pump. The last owner said something about phase 4 for injectors and pump. He couldn't remember which fuel plate#.
Any advice on Dr Performance? Or is it complete crap?
Thanks,
Greg
Old Nov 12, 2007 | 02:27 PM
JD730's Avatar
I can tell you its a dodge trans and if its a 94 or 95 it will have a 47RH and if its a 96 to 02 it will have a 47RE.
Old Nov 12, 2007 | 11:46 PM
HelenaTDI's Avatar
It's a 98 tranny. Apparently been beefed up. Triple clutch, valve body, torque converter. Previous owner doesn't remember if it's a DTT or ATS, etc.... I was hoping to identify by someway on the exterior casing. The stamping is all I found.
Old Nov 13, 2007 | 12:34 AM
catnfool's Avatar
an ATS is purple/has a purple tourque converter with a billit face. You will see this when you pull off the four bolts on the inspection cover between the tranny/engine. Dr. performance has a shop in Helena (or sell Workhorse moduals- I heard they changed names) and Dave Smith used to install them in ID. Other than that, hello from the other side of the hill...(Kalispell) bruce
I have heard good things about Dr Per. stuff- do you smoke much?
Old Nov 13, 2007 | 06:39 PM
HelenaTDI's Avatar
oh hell ya I smoke. I don't think Dr Performance is a real specialist in diesels. I have heard he is kind of a hack. I'm looking to get his stuff removed and go with someone else. As far as my torque converter I removed the inspection cover and it is light gray. I'm still trying to identify which type of tranny this maybe. As it is heavily modded. The previous owner said it was bullet proof. I'm just suprised he couldn't remember who did it? Go figure. Anyway thanks for the info. It has been a great informational site. I also use TDIclub.com site as I own a VW diesel. It's great to have all these good forums.
Old Nov 13, 2007 | 08:05 PM
dieseldemon's Avatar
DR performance stuff is junk when he first started I asked him what qualified him to work on diesels and he said I OWN ONE
Old Nov 13, 2007 | 08:42 PM
DR Performance stuff is JUNK when he first started I asked him what qualified him to be a mechanic he said I OWN ONE
Old Nov 14, 2007 | 04:04 PM
HelenaTDI's Avatar
Yeah I found out Dr Performance is complete garbage. I found that out after I bought the truck. Luckily it's a 12V and can be corrected without too much pain. The guy is a hack for sure.
wakecrazy22ssv
Sep 22, 2011 10:40 PM
DodgeRamdiese01
Aug 28, 2009 06:44 AM
NOSTROKER
Feb 21, 2008 03:40 PM
FAY
Mar 29, 2006 08:14 PM
03blkdrw
Mar 28, 2006 12:45 PM
