mopar brake pads
Old Aug 30, 2006 | 09:55 AM
expressfish's Avatar
mopar brake pads
so makes mopar brake pads ? does mopar manufacture them or does someone else make them like raybestos ? looking to replace my pads here soon and want a good pad......
Old Aug 30, 2006 | 10:20 AM
infidel's Avatar
For the best buy Hawk pads from www.tirerack.com
Old Aug 30, 2006 | 11:57 AM
gmctd's Avatar
The new MOPAR pads on mine squeal on the new rotors at initial application, lite or heavy
I coulda had the same service from the 'zone for much, much less.....................
Old Aug 30, 2006 | 02:47 PM
DL1221's Avatar
Definitely don’t buy the Dodge pads.
I was going to use the Bendix Fleet Metallic Heavy Duty pads on my truck, because I’ve used them before on other vehicles. However I’ve heard a lot of people boast about the Hawks in this forum, are they really the best pads, and why? I was happy with the Chevy wheel cylinder upgrade that I learned about here, so if I hear enough good things about the Hawks, I’ll buy those instead of the Bendix ones
Old Aug 30, 2006 | 04:05 PM
hawks
there are several "hawk " brand pads------which ones are you using infidel ??
Old Aug 30, 2006 | 06:42 PM
infidel's Avatar
The cheapest ones, HPS. The more expensive heavy duty ones tend to squeak.
Why I feel Hawks are the best:
Their hardness is a perfect match to our rotors, they won't wear the rotor nor produce too much dust.
Beware of the warrantied for life pads. The reason they are able to warranty them is because they are so hard that your rotor wears out before the pad does. Ceramic pads tend to do this also.
Old Aug 30, 2006 | 07:10 PM
gmctd's Avatar
The greater the metallic content, the greater the rotor wear - I agree, get the most organic, least metallic pads if you're replacing the pads and rear shoes.
If replacing only the pads, you'll need to match them as closely as possible to the rear shoes to maintain the correct f\r bias - prevents lockup\skidding on slick streets.
Old Aug 30, 2006 | 08:23 PM
fschiola's Avatar
I went to Tire Racks site and all I found were a brand called "Satisfied Pro". Are these the ones you're talking about?
Old Aug 30, 2006 | 08:25 PM
fschiola's Avatar
Never mind, I found the page that has the brand selector on it. But when I put in my 2000 they say they have no components for it.
Old Aug 31, 2006 | 10:46 AM
infidel's Avatar
Don't trust their website, call them.
Most often they do have what you need.
Dodgezilla
Mar 7, 2010 12:13 PM
Seelow
17
Oct 3, 2009 08:02 AM
Chip
14
Jun 21, 2009 03:59 AM
maarten
Apr 30, 2003 09:42 PM
