mechanics?
I need someone to trouble shoot my fuel system. I'm pretty sure it just needs a new lift pump, but I want to be sure. I'm trying to stay close to ft knox, so towing it won't be to expensive
well its sitting dead now. the only way I can get it to run at all, is if I prime it at the lift pump, then it will only run for about 15-20 seconds and die. The injection pump seems fine-its only 3 years old, and my fuel lines look to be intact, if a little dirty. I've not looked at my injectors, but the previous owner had them replaced about 4 years ago, along with having the entire fuel system cleaned and checked(he left me a ton of reciepts)
Were you having problems before you did the maintenance? I've only replaced my lift pump twice. The first one had over 300k and the second nearly 400k. Neither one had totally failed, just ticked due to weakened springs.
Have you ever replaced the rubber fuel hoses? Sounds like the classic sucking air. You have two long hoses, one from the tank and a return hose. The is also a rubber L shaped hose between the prefilter and the pump. The L shaped hose is about $8 from Dodge. If it won't stay running it is probably either the hose from the tank or/and the L shaped hose. If it will stay running but is hard to start it is usually the return hose.
The fuel shutoff solenoid is working fine (1st thing I checked), I have not replaced any fuel lines, but I did take a look at them, and they seem intact, can't find any holes, leaks or kinks in them. Would the truck run at all if they were screwed up? Also, when I can get it to run for a few seconds, its blowing some whiteish blue smoke out the exhaust. Right before it died, it seemed to be blowing a lot more black smoke as well...at least more than usual.
........ they seem intact, can't find any holes, leaks or kinks in them. Would the truck run at all if they were screwed up? Also, when I can get it to run for a few seconds, its blowing some whiteish blue smoke out the exhaust. Right before it died, it seemed to be blowing a lot more black smoke as well...at least more than usual.
