Tranny Help
Old Jan 23, 2010 | 08:26 PM
adub12valve's Avatar
From: Prineville, Oregon but going to school at Mayville State University, North Dakota
Tranny Help
I found a NV 4500 Dodge Transmission Rebuilt with a warranty for a good price. Is this a good deal and will it work on my truck? I have a 98 12 valve automaic.
Thanks Andrew
Old Jan 23, 2010 | 09:20 PM
Andy505's Avatar
Should work as long as its a Diesel/v10 unit, not sure if the autos are different in the output shaft splines, so your rear drive shaft/transfer case (depending on whether you have a 4x4 or not) will fit into the back of the tranny, driveshaft lengths may need to be lengthened/shortened depending on auto to manual tranny length differences.
As for the front of the manual tranny, new flywheel for a manual, clutch, inside the truck you'll need a clutch pedal that hooks to a slave cylinder. I think the pedal system is a whole assembly.
I'm sure someone here has done the swap, hopefully they'll chime in.
rjweiss
Jun 4, 2011 07:48 PM
Black Dog
Dec 3, 2009 08:18 PM
4doogie
Dec 15, 2008 12:37 PM
davelinde
18
Jul 14, 2008 08:34 PM
Common
Jun 9, 2008 12:16 PM
