Loosening the driveline pinion nut
Old Jan 19, 2006 | 03:46 PM
alaskanassassin's Avatar
I need to replace the pinion seal and need some ideas on how to loosen the 1 7/8 nut, which is torqued to 450 lbs. I tried a 1/2 drive impact, 1:4 multiplier, and a cheater and I still could not budge it. Any ideas would be appreciated. Doug
Old Jan 19, 2006 | 03:51 PM
newriverSpecon's Avatar
Bigger impact or higher air pressure. I belive I used a 3/4" impact on my 99. Also we run 160 PSI. I had to use our bug air hammer (rivet gun that is twice the size of the 3/4 impact) to drive the pinion out. Our 4x rivet gun was not enough.
Randy
Old Jan 20, 2006 | 02:15 PM
Txwelder's Avatar
I did mine in the driveway and didnt have any trouble getting it off with a very large Snap-on ratchet set. I think it was a 3/4" drive. Worked like a champ.
Old Jan 21, 2006 | 05:52 AM
infidel's Avatar
Thought I answered this but now it's gone...
Use a long breaker or one with a cheater pipe and roll the truck forward with the breaker hitting the ground.
Old Jan 21, 2006 | 09:21 AM
Thanks for all the input. Doug
Old Jan 21, 2006 | 01:15 PM
turbo thom's Avatar
Bill..........Good to hear you have that too. I thought I was nuts. Well, nutieerererererer than y'all think already.
..Preston..
Old Feb 22, 2010 | 07:29 PM
redramnc's Avatar
Sometimes simple is good
BTDT, too. Several times over the years. Not as crazy as it sounds if it gets the job done properly.
Old Feb 22, 2010 | 08:23 PM
A. Bomb's Avatar
Ingersoll-Rand 2135Ti @ 125 psi and a proper OTC impact socket. Like it wasnt even there.
Good tools for the win.
Old Feb 22, 2010 | 08:34 PM
Purplezr2's Avatar
yep
royta
Mar 16, 2007 04:30 PM
blueberry
Feb 11, 2007 09:10 AM
biglar
Oct 22, 2006 04:17 PM
Sean Allan
Aug 9, 2006 01:38 PM
Bobcat698
Oct 26, 2005 06:19 PM
