P7100 - loosening star wheel vs. sliding AFC housing
Old Mar 16, 2007 | 12:53 PM
royta's Avatar
Right now, I have my star wheel loosened so much that the spring is actually loose in the housing. Would I be able to control the low end (pre-boost) fuel a little better if I tightened up the star wheel to the point that the spring has a slight amount of tension, and then slid the AFC housing forwards? Has anybody experimented with this? I'm wondering if there would even be a difference at all.
Old Mar 16, 2007 | 04:03 PM
Lil Dog's Avatar
Big difference if you have not moved the housing yet. Once you move the AFC forward, you move the point of low fuel ahead. It will smoke alot more if you don't back out the zero boost screw on the back end of the AFC housing.
Old Mar 16, 2007 | 04:30 PM
royta's Avatar
Could you explain, or point me to a link with the explanation, of zero boost screw on the back end of the AFC housing. I have a pretty good idea of the screw you're talking about, but I haven't seen any literature on what it actually does.
izzwardo
Jul 31, 2009 06:29 PM
whatsup1287
Jun 19, 2009 09:05 PM
Tuckerdee
Mar 20, 2006 07:45 AM
Bobcat698
Oct 26, 2005 06:19 PM
