Loosening the driveline pinion nut
I need to replace the pinion seal and need some ideas on how to loosen the 1 7/8 nut, which is torqued to 450 lbs. I tried a 1/2 drive impact, 1:4 multiplier, and a cheater and I still could not budge it. Any ideas would be appreciated. Doug
Bigger impact or higher air pressure. I belive I used a 3/4" impact on my 99. Also we run 160 PSI. I had to use our bug air hammer (rivet gun that is twice the size of the 3/4 impact) to drive the pinion out. Our 4x rivet gun was not enough.
Randy |
I did mine in the driveway and didnt have any trouble getting it off with a very large Snap-on ratchet set. I think it was a 3/4" drive. Worked like a champ.
Thought I answered this but now it's gone...
Use a long breaker or one with a cheater pipe and roll the truck forward with the breaker hitting the ground. |
Thanks for all the input. Doug
Bill..........Good to hear you have that too. I thought I was nuts. Well, nutieerererererer than y'all think already.
..Preston.. |
Sometimes simple is good
BTDT, too. Several times over the years. Not as crazy as it sounds if it gets the job done properly.
Ingersoll-Rand 2135Ti @ 125 psi and a proper OTC impact socket. Like it wasnt even there.
Good tools for the win. |
Originally Posted by A. Bomb
(Post 2708762)
