Looking at a 94, few questions
Old Sep 20, 2009 | 12:29 PM
6cylinders's Avatar
Looking at a 94 3500 dually 4 wheel drive.Pickup bed.
What differential gear ratio, or how can I tell, is there a sticker somewhere?
WHich auto transmission would this have?
Which transfer case?
Injection pump?
It has 222K miles, any common problems to look for?
What about ball joints, front suspension problems?
KDP fix will be on the top of my list if I get it.
Thanks
Old Sep 20, 2009 | 12:46 PM
12v rollincole's Avatar
What differential gear ratio: 3.54, 4.10
Which auto transmission: 47rh
Which transfer case: NV241D or NV241DH not sure
Injection pump: 160 p-pump
front end problems: track bar is the biggest.
Im not what youd call an expert so here is some good info http://dodgeram.org/ , and im sure someone more knowlegable will correct me if im wrong on anything.
good luck, matt
Old Sep 20, 2009 | 02:27 PM
RPegram's Avatar
Injection pump?
Thanks
If it still has original hood and not been painted on inside, most have a sticker with model, type, gear ratio and which transfer case. It should have a 47rh trans. On the side of the timing cover in front of pump will be a tag with all information for engine (HP, model, serial, timing, etc.). Biggest problems are rust, blowby and oil leaks. I would plan on complete front end rebuild, add aftermarket or late model track bar and steering brace for steering gear.
Old Sep 20, 2009 | 04:11 PM
Hodge's Avatar
Find out if the trans has ever been rebuilt. If not, it probably will need it.
bansh-eman
15
Sep 21, 2009 11:11 AM
learners_permit
Sep 18, 2007 01:38 AM
loki993
Nov 10, 2006 01:42 PM
GoodoleBob
Sep 27, 2006 11:37 PM
