Lockup switch overide tps
Old Feb 11, 2007 | 10:44 PM
Buckshotram's Avatar
Would a lockup switch override a faulty tps. If it would how do you wire up for a 95 47-rh thanks.
Old Feb 12, 2007 | 10:24 AM
infidel's Avatar
Yes it will
Instuctions> http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Scroll down for '94-'95
Old Feb 12, 2007 | 10:45 AM
Thanks infidel, my mechanic said tps is fine but im having a hardtime thinking the trans is going south with less than 20k in it.
Besides the brake switch is there anyother thing that would cause the tc to unlock while going down the road.
Old Feb 12, 2007 | 05:05 PM
Mopar440_6's Avatar
Ive been considerin a lockup switch for a while but I just want to make sure I understand correctly. If I have the switch closed (grounded) the converter is locked correct? But if the switch is off the truck will lock and unlock itself as usual?
Old Feb 12, 2007 | 05:09 PM
mainer's Avatar
that is correct
Old Feb 12, 2007 | 06:40 PM
infidel's Avatar
The main problem (possibly the only one) with a lockup is forgetting to unlock when coming to a stop. It will be the same as stopping in gear with a manual without pushing the clutch.
Old Feb 12, 2007 | 09:05 PM
CarlJensen's Avatar
Have you checked your brake light switch? If it is loose or malfunctioning it can cause lock up loss as the tranny thinks you put on the brakes. Just a thought.
Old Feb 12, 2007 | 10:00 PM
b.lee's Avatar
mine locks and unlocks constantly.(depending on throttle position)
I think the TPS is screwy.
I read about a nice little filter over at http://dodgeram.org/tech/transmissio...TPS_adjust.htm
whosdunit
May 17, 2014 08:54 AM
cowboykilla235
Feb 17, 2013 03:02 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
W1cked
Dec 19, 2006 09:40 PM
