lift pump question
Old Nov 9, 2007 | 12:06 AM
twinturbos's Avatar
lift pump question
my buddy had a fuel leak at the lift pump the other day. so he ordered a holley blue electric fuel pump. He eliminated the lift pump all together and put a plate over the hole. now he is just runnin the holley all together.. has anybody else done this?.. is it ok to do?.only thing i was worried about was the right amount of fuel pressure.. i dont know any replies would be great.. my lift weak and if its ok to do that, ill go that route..thanks
Old Nov 9, 2007 | 12:12 AM
Dr. Evil's Avatar
Are you talking about a 12V??
If so, no this isnt a good idea. A Holley blue only puts out 14 psi or so, iirc...on a 12V you need a lp that will supply 40 psi...
Old Nov 9, 2007 | 12:19 AM
twinturbos's Avatar
yeah sorry its a 12 valve. it sure runs like a champ though
Old Nov 9, 2007 | 12:24 AM
Dr. Evil's Avatar
But hes starving it of fuel.
I dont know why someone would take off a buletproof lift pump and replace it with an electric that will last a short time.
Old Nov 9, 2007 | 12:25 AM
twinturbos's Avatar
alright thanks for reply ill let him know
Old Nov 9, 2007 | 02:37 AM
Tate's Avatar
I ran my FASS (18psi) for about two months, ran great, never an issue. When I went to 45psi setup, there really wasn't much difference other than my FP gauge is constantly pegged.
Old Nov 9, 2007 | 09:55 AM
Dr. Evil's Avatar
I wonder why the stocker moves so much fuel then?
Old Nov 9, 2007 | 10:07 AM
infidel's Avatar
To cool the injection pump
Old Nov 9, 2007 | 10:15 AM
Dr. Evil's Avatar
I thought it was lubed by oil. But the fuel does the cooling??
Old Nov 9, 2007 | 11:44 AM
infidel's Avatar
Most of the P pump is cooled/lubed by oil unlike the VP but fuel cools the parts of the pump not reached by oil such as the DVs and plungers.
Think about it, oil and fuel aren't mixing in the pump.
Old Nov 9, 2007 | 12:23 PM
Lil Dog's Avatar
One of the things I don't like about electric is that is supplies the same flow regardless of engine speed. The mechanical lift pump increases flow with RPM obviously. But with a bump in pressure at higher RPM, you are bumping the timing a tad in the process.. There is method to the madness..
Old Nov 9, 2007 | 11:06 PM
Tate's Avatar
When I had the low pressure FASS on it, it was 18psi at idle, and 16psi at WOT. I had a much greater drop with my VP than I did with the p-pump. Whats the flow rating on the stock lift pumps at various rpms? The lowest GPH FASS out there is a 90, which seems it would fit the bill for most people here.
Txwelder
Nov 26, 2025 01:53 AM
ScreaminEagle
Oct 31, 2007 03:31 PM
Txwelder
May 19, 2005 06:10 PM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
