Leaky afc line
Old Jul 19, 2007 | 05:40 AM
schoust's Avatar
Leaky afc line
Guy's I think I have a very small leak in my afc line and I would like to replace it,has anyone done this with materials other than staock? If so what can I use? Is this just 1/4 inch plastic line by compression?
Old Jul 19, 2007 | 08:29 AM
513yj's Avatar
when i pulled mine off to get the afc off it looked like the compression fittings on air brake lines. it has the nut and the ferrule inside that crushes onto the line just like a oil or turbo line. i'm thinking i would use air brake stuff since it's made not to leak and you can get the npt on one end and air fitting on the other. i noticed it didnt have the nipple that air brake lines have tho. not sure why but i don't think if you replace both ends and the line itself it is gonna hurt.
Old Jul 19, 2007 | 01:23 PM
schoust's Avatar
You know I was thinking air line would work to,anyone else care to chime in? Infidal??
Old Jul 19, 2007 | 06:25 PM
clutch1's Avatar
air line will work. do you have extra tubing that you used for your boost guage? or any line as long as it has the compression fittings
Old Jul 19, 2007 | 10:43 PM
marks2500's Avatar
hello, i just rebuilt my valet switch and used 1/8 to 3/16 brass ferral fittings on the manifold and afc housing. (kind of like your brass boost guage fitting on the manifold) 4 fittings, 1 ball valve(inside cab), 10ft 3/16 hose=$10.00
Mark
Old Jul 20, 2007 | 05:07 AM
schoust's Avatar
Thanks Mark thats what I was looking for the sizes that are needed.
Old Jul 20, 2007 | 02:15 PM
crankbender's Avatar
I used air brake hose on mine.
One thing to consider, I noticed that one of the original brass fittings (can't remember wich one) has a restricting orfice built into it. My thinking on this was it was put there to prevent massive amounts of air from entering the crankcase if the AFC diphram was to ever tear. Somthing to keep in mind.
Old Jul 20, 2007 | 06:07 PM
schoust's Avatar
Hmmm what do you think the extent of the damage would be if the diaphram was torn with a modified afc line???
Old Jul 20, 2007 | 09:48 PM
I realy have no idea what or if any dammage would be done it you rammed 40psi boost through a wide open line into the pump. You could always put a valve in the line and pinch it back.
In fact I have a valve ran into the cab where I can controll the rate the AFC moves forwards or put it into full valet mode. It worked good to controll smoke with the stock and hybrid chargers I had with -300hp fueling. With the 62-14 charger and -400hp fueling it REALY shines when towing and eliminates the surge (bark) I would get by slowing the fueling rate down. Going this route it is neccesary to put a small valve down stream of your throttle valve to bleed off air that could be trapped between it (throttle valve) and AFC
Old Jul 21, 2007 | 10:39 AM
halfpint23's Avatar
OK guys, not to hijack a thread, but I HAVE to ask.
What is this "valet mode" thing - what's DO and what does it do it with? I have searched archived posts and found a lot of references to it, but never come across a description of what etc.
Please, somebody, enlighten me?
Old Jul 21, 2007 | 07:19 PM
schoust's Avatar
The Valet on a 12 valve is simply a device (ball valve) that will interrupt the air signal from the manifold to the AFC. I use it to save on fuel and keep my egts in check when in the vegi mode.....
Old Jul 21, 2007 | 08:03 PM
Dshiftff's Avatar
ralph i have a lead on stock 160 injectors for sale if your still interested in seeing if thats the issue..
Old Jul 21, 2007 | 08:14 PM
schoust's Avatar
Thanks Jim but I the guy from Pensicola Diesel sent me one so that I can send him my stage twos for clean up and pop test. I can't say enough about those guy's at P. D. whats funny is the guy said to me that Bio Diesel and Vegi guiy's are good for his buisness LOL!! Hey I still need to borrow that socket,would it be possible this week I'm off until Wendsday and those 160's can use a bit more fuel!!
RussianVolk
Jun 29, 2010 01:13 AM
harleydodge
May 9, 2007 07:49 PM
hotmopr
Jun 29, 2006 10:22 PM
royta
Feb 15, 2005 10:15 PM
