leaking power steering pump
Old Aug 24, 2006 | 05:29 PM
Baja's Avatar
Went under the truck today and noticed the engine wet. Traced the source to the bottom of the PS pump. Another symptom I have noticed is that it groans when I turn the wheels. Is it dying on me? Are these repairable, or is it best to get a rebuilt one, (where?) trading in the core? Thanks in advance.
Old Aug 24, 2006 | 05:43 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
I have serviced several of them they are just a simple vane pump, but it is much easier to just get a used one or a reman although they can be expensive. try http://www.uneedapart.com/ use their search i have had good luck with them. First though make sure it is full of fluid and that your leak is not a hose of loose fitting, power steering pump failure is somewhat rare.
Chris
Old Aug 24, 2006 | 06:43 PM
GAmes's Avatar
There is a o-ring rebuild kit for it. Not too expensive. Call
http://www.hotroddiesels.com/
Old Aug 24, 2006 | 08:54 PM
P.O.R.'s Avatar
try this site also, www.fixinrams.com
plow's Avatar
The o-ring inbetween the vacuum pump and the power steering pump is usally the place it leaks. You can order parts here http://www.fixinrams.com/id14.html
Old Aug 24, 2006 | 08:56 PM
plow's Avatar
sorry P.O.R looks like we chimed in at the same time.
Old Aug 24, 2006 | 09:58 PM
P.O.R.'s Avatar
no problem,
Old Aug 24, 2006 | 10:17 PM
loosendend's Avatar
The o-ring was about 7.00 dollars, replaced mine less that a month ago.
92smokin blacky
Mar 30, 2010 06:09 PM
niekrewb
Mar 21, 2005 09:19 AM
Twalker
Feb 3, 2005 11:31 AM
BLK_RAM
Dec 31, 2002 12:10 PM
USMC64-70
Nov 25, 2002 11:13 AM
