Killer Dowel Pin, KDP, Culprit?
Old Jan 16, 2010 | 11:12 AM
97_Dually's Avatar
As posted before, I had to replace the engine in the '97 with a '94 F700 bus engine, after switching many parts its running great.
After dropping the oil pan from the original engine, we found the 2nd cyclinder back was missing the rod bearings, the rod slaps loose on the crank.
That created the knock. After pulling the timing gear cover off, I found this...
Do you see whats missing in the pic?
Old Jan 17, 2010 | 08:50 AM
kyle_truck_pull's Avatar
How long is the kdp? I'm guessing u never found the pin?
Old Jan 17, 2010 | 11:23 AM
97_Dually's Avatar
Not sure how long it is; I'd guess 1/2 inch.
We found something laying on one of the timing gears, which might have been it.
Mostly there was lots of metallic dust all in the oil pan, and oil filter.
Old Jan 17, 2010 | 11:47 AM
burt's Avatar
I just made a keeper for that problem on an engine this last week. when I put the bolt in next to the dowel pin, I took a peice of .040" shim and cut it to cover that dowel and the bolt next to it holds it in place.
Old Jan 17, 2010 | 02:08 PM
what is that pin there for originally? can u just leave it out or do u have to cover the hole?
Old Jan 17, 2010 | 02:30 PM
roughstock's Avatar
the pin is used for assembly. it is an alignment dowel for positioning the timing case to engine. Id make sure that it is in there when you put it back togeher, to make sure there is no movement in the case some day.
Old Jan 17, 2010 | 03:19 PM
No way did the KDP hurt a rod bearing.
Old Jan 18, 2010 | 07:46 AM
97_Dually's Avatar
Heres where I made my "tab" in the "new" 94 cpl 1550 f700 engine I replaced the old one with.
pic is in this thread.
https://www.dieseltruckresource.com/....html?t=250595
Old Jan 18, 2010 | 07:50 AM
97_Dually's Avatar
I bet it didn't help the situation, tho.
atmechanical
Jun 1, 2011 10:57 PM
dieselcarpenter
Sep 15, 2007 01:12 PM
rush47
14
Mar 16, 2006 06:55 PM
Greguw
Oct 16, 2005 01:25 PM
Holycack
Jun 25, 2003 02:16 PM
