killer dowel pin years
Old Dec 26, 2005 | 12:53 AM
rush47's Avatar
From: kandahar afghanistan for awhile, normally Tri-Cities Wa.
Just trying to confirm that my 24 valve has the kdp syndrome. I'm sure it has not been addressed by the original owner. I just wanted to confirm it's a problem with 24 valve engines also before I tear into mine to secure it.
thanks
grant
Old Dec 26, 2005 | 07:47 AM
Every '98 truck I've done had the old case. Sometime in '99 MY they switched cases, I've seen both cases on '99 trucks.
Old Dec 26, 2005 | 10:06 AM
MARKY MARK's Avatar
Is there a way to tell if I have the old or new case?
Mark
Old Dec 26, 2005 | 01:22 PM
Not from the outside.
Old Jan 2, 2006 | 12:49 AM
99NVRam2500's Avatar
OK, which case, how hard is it to open, and What does this thing do?
Old Jan 2, 2006 | 07:15 AM
russ300h's Avatar
The case where your Injection pump and vacuum pump mount. My first took six hours, my second about two. The pin locates the case to the motor for assembly and keeps it in alignment in use. It NEEDS to be there or you will cause other problems, it NEEDS to be fixed or you can cause serious damage.
Old Jan 19, 2006 | 03:24 PM
Prodart440's Avatar
I own a 3rd gen but a freind has a 2nd Gen. He has a 12V. Does this KDP apply to his truck also??
Aaron
Old Jan 19, 2006 | 03:27 PM
farmer dave's Avatar
Yes, if he has a 12v he has a kdp.
Old Jan 20, 2006 | 08:16 PM
HawaiiCTD's Avatar
Are the KDP only in the 12v?
Truck in question 01.
Old Jan 20, 2006 | 09:24 PM
Dr. Evil's Avatar
No...24Vs are included...just read the posts above. But, luckily, its not an issue on an 01
Old Jan 21, 2006 | 11:39 AM
Copenhagenjunkie's Avatar
thanks
grant
I would do it just to be sure.
Old Mar 16, 2006 | 04:54 PM
Truckman's Avatar
Question
Dr, Evil are you sure about the 01 not being an issue with the KDP?
I just bought an 01 and have the front cover off. I cant find on this site a photo of a new case and an old case to compare. I have a photo of mine,,I am trying to post in my gallery but have to wait for approval... Could someone look for me in my gallery and let me know..OR where I can see old case photos and new case photos?
Thanks..
Old Mar 16, 2006 | 06:14 PM
piperca's Avatar
There is a shoulder on the hole, which is there to stop the pin from coming out further. You are fine! I have my own opinion regarding the 24 valve dowel pin issue, but I'll keep that to myself ... just in case I ruffle some feathers ... right, Dr.
Old Mar 16, 2006 | 06:19 PM
Geico266's Avatar
Looks just like my NEW CASE and I have an early "99".
I got caught up the KDP frenzy last fall and checked mine. 4 hours later I discovered I was worried about nothing.
If someone says now I can sleep better my head is gonna explode!
Old Mar 16, 2006 | 06:55 PM
Truckman's Avatar
Talking Kdp
We are going to take a pick and feel inside for the lip that should be there to retain the dowel.
Thanks for all your help,
Putting a 2001 in my 1998.5 Truck. Trying to cover all bases.
keithw1975
14
Jul 3, 2007 10:25 PM
Abbynormal
Mar 9, 2006 07:53 PM
Abbynormal
16
Mar 8, 2006 09:03 PM
Greguw
Oct 16, 2005 01:25 PM
Holycack
Jun 25, 2003 02:16 PM
