intercooler boot
Old Feb 10, 2005 | 10:23 AM
doodah's Avatar
intercooler boot
guys, I was going through some general maintenance on my truck, like checking tranny lines for rub, while I was taking off my sport front end that I SOLD! {sorry blue!} but anyhow I saw a about a 1/2inch tear in my intercooler boot. the boot that runs underneith the radiator support on drivers side! is this hurting boost? I have not got my gauges in yet to tell, and I do not really now because of the way it runs because I have not drove it much lately! It is just a slit, Could I put some duct tape over this until I get a new one? where do I get a new one at? they are kindof expensive arent they? cant I use a piece of rubber hose the same size? thanks in advance guys!
Old Feb 10, 2005 | 10:38 AM
dodgeman01's Avatar
I had a rub mark on both my lower intercoller boots. If I was you right now I would buy the PDR intercoller boots. I bought them and gained5 PSI of boost
DM01
Old Feb 10, 2005 | 11:28 AM
gunracer1's Avatar
try these guys http://stores.ebay.com/High-Temp-Sil...dZ2QQpZ3QQtZkm
Old Feb 10, 2005 | 02:03 PM
infidel's Avatar
If you've ever pressurized your intake system to 35 psi with an air compressor looking for leaks it's easy to see how a little leak can become bigger with boost and how a boot that has plenty of clearance can start rubbing on the fender. The first time I pressurized one it was downright scary how much the stock boots balloon out. The boots Piers sells are much heavier duty, don't balloon and are cheaper than the stock boots to boot.
Old Feb 10, 2005 | 05:28 PM
tdiot's Avatar
The *********** wanted $155+tax from me for one boot!!!!!!! I found some perfect used ones for a small fraction of that, but the more solid aftermarket ones that Piers sell look like a good deal. Being thicker I`m sure they are fun to put on but well worth the effort! Good used ones on Ebay seem to go for $40+ each.
Old Feb 10, 2005 | 09:17 PM
Whitmore's Avatar
I got a whole stack of used ones and wouldnt give them to anybody, gonna throw them away, they will just cause troubles for a fellow rammer...........dont want that
Old Feb 10, 2005 | 10:19 PM
doodah's Avatar
WHAt do you mean? I don't think they are that bad, are they? they/re not like a tire, that you change every so often. I would take one off your hands for a price. maybe even 2. I can't afford to buy new!
Old Feb 11, 2005 | 07:15 AM
Palmetto_kid's Avatar
Those PDR boots are tough!
If you have a 99+, and you have never looked at your lower boots, then you better. I think they put a bigger intercooler in during 99-02 because there is not as much room as the 12valves. The fender was cutting into the lower boots on my 01, and on my grandpappys 01.
Old Feb 11, 2005 | 08:04 AM
tdiot's Avatar
While I agree with you Whitmore, many of us are trying to keep our ageing rigs running down the road on a very tight budget! A stock boot with no holes is still better than a stock boot with a tear. If we`d had this discussion last week, when I was in dire need for a boot I would have been at your house on trash day! Take care!
Old Feb 11, 2005 | 08:44 AM
Whitmore's Avatar
I have the HD boots from Piers and there is NO comparison with the old ones, They are only half as thick and if you do a pressure check like infidel says you prolly wouldnt want the stockers if you saw how they blew up like a balloon.
Cheers, Kevin
Old Feb 11, 2005 | 09:31 AM
infidel's Avatar
If you don't change to the PDR boots at least cut a section of garden sized hose lengthwise and slip it over the sharp edge on the lower fender. Saves you from a headache down the road.
Old Feb 11, 2005 | 11:09 AM
halerazor's Avatar
its your lucky day piers has boots on special for $190 for a complete set
Old Feb 11, 2005 | 12:10 PM
tdiot's Avatar
Thats a very good deal! Top and bottom, both sides with clamps for $190. Like I said the dealership wanted $155 for ONE lower and inferior boot!
95black2615
Oct 8, 2008 03:34 PM
sammy340
Oct 24, 2005 07:30 PM
windkid4
Jul 9, 2005 09:06 PM
WTTD
May 28, 2003 08:03 AM
csaverline
Oct 23, 2002 04:55 PM
